99 Wheel size - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 05-06-2011, 11:20 AM Thread Starter
99 Wheel size
Hey guys I was just wondering if anyone knew the size (width) of the stock rims on a late 99 F-350 srw. Also, i was wondering if i could run a 315/75 R16 (35x12.50 R16) on theese rims. Thanks
[B]Late 99 F-350[B] SC LB 4X4 6spd Manual
All stock ( for now)
diesel farmer is offline
post #2 of 4 (permalink) Old 05-06-2011, 12:56 PM
white7.3's Avatar
Re: 99 Wheel size
Pretty sure there 16 x 7.5 or 16 x 8...
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
6.0 I/C Van Turbo & WW
6637 Intake 5" Exhaust
Custom RR Fuel System
05 Grille/08 Center Console
Raptor 372 w/ Toyo Open
Country AT2 35/12.50
white7.3 is offline
post #3 of 4 (permalink) Old 05-09-2011, 01:43 AM
"Smoke A Lil Smoke"
chappy's Avatar
Re: 99 Wheel size
there either 16x7 or 16x7.5 . Technically you are not suppose to run that wide of a tire on the rims but it has been done many times. The main thing if you do would be to make sure you play with the air pressure to get them to run even across tread. The bad thing is I have seen some tires crack around the outside because they are sucked in to much. bfg A/t's seem to be bad for it. If it was me, I would pic up some 16x10's I have seen them cheap on craigslist many times because they are not a popular size.
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
chappy is offline
post #4 of 4 (permalink) Old 05-09-2011, 01:58 AM
ford_trck's Avatar
Re: 99 Wheel size
I haven't run 305's but a 285 will fit with no problems at all. If you can find them I'm pretty sure a 295 will also fit without clearance or rubbing issues.
Early 99 F-350 CC LB 6-speed
Turbo, injectors, fuel, clutch, nothing special
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
Originally Posted by HeWhoIs View Post
The only brutha you know is the one that's bangin your little sister you cracka.
ford_trck is offline
