Warped Rotors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 05-02-2011, 02:47 AM Thread Starter
edge186's Avatar
Warped Rotors
I have at least a couple rotors that are warped. They all have plenty of life left in them. question is, are they worth turning or is it cheaper to just replace them? If I replace them, are there any particular brands that are better than others?
thanks
2001 F-250 PSD 4x4 Lariat CC SB Auto
Power Hungry Performance
Edge CTS Insight
ATS 4" Straight Pipe
ATS Ported Compressor Housing
AFE Stage II Intake
DI Stainless Up-Pipes
BTS Valve Body
6.0 Billet Converter
6.0 32 Row Trans Cooler
Foil Delete
AIH Delete
CCV Mod
Firestone Ride-Rite airbags
edge186 is offline
post #2 of 22 (permalink) Old 05-02-2011, 02:58 AM
Diesel Sled Head
zx800x's Avatar
Re: Warped Rotors
Usually you are better off replacing them. When you machine them there is less material and they can tend to warp easier. I was impressed with the rotorpros pads and rotors.
2001 f250 H2E,BTS,Stealth,reg return,mod IDM, spearco,DI Ceramic Headers.. bcode stage 3's Cale's Tunes
zx800x is offline
post #3 of 22 (permalink) Old 05-02-2011, 03:01 AM
<----Nice headlights!!!
TylerDurden's Avatar
Re: Warped Rotors
Yes...differential cooling is what warps them in the first place. Usually anyway. Machining them usually exacerbates this problem.
Id love a baer upgrade kit for these. I always pitch them cuz I consider them unserviceable.
2000 F250 4x4 cc/sb. 6" w/37's and some other stuff.
TylerDurden is offline
post #4 of 22 (permalink) Old 05-02-2011, 03:24 AM
Caption This
444-4D's Avatar
Re: Warped Rotors
Rotors don't warp. The pedal pulsation you feel is caused by a difference in rotor thickness. The difference in rotor thickness is caused by runout(wobble).
When the hub/rotor assembly has runout the rotor bumps the pad as it turns. Where it bumps the pad it will make thin spot. If you want to fix your brakes you will need to fix the runout.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #5 of 22 (permalink) Old 05-02-2011, 03:35 AM
Hood Rich
CTC DEEZUL's Avatar
Send a message via AIM to CTC DEEZUL
Re: Warped Rotors
Originally Posted by 444-4D View Post
Rotors don't warp.
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
CTC DEEZUL is offline
post #6 of 22 (permalink) Old 05-02-2011, 03:56 AM
Caption This
444-4D's Avatar
Re: Warped Rotors
Originally Posted by CTC DEEZUL View Post
Careful, you are in over your head.
444-4D is offline
post #7 of 22 (permalink) Old 05-02-2011, 04:17 AM
Hood Rich
CTC DEEZUL's Avatar
Re: Warped Rotors
So when one is riding the brakes, say a woman... than this woman hits a puddle of water... then all of a sudden she has wobbly feeling everytime she brakes.... now she has different thickness's in her rotor surfaces???
via Beans Toonz
DI SS Up-Pipe
GTP38R
post #8 of 22 (permalink) Old 05-02-2011, 04:30 AM
Go Away I'm Baitin
fishinfool98's Avatar
Send a message via AIM to fishinfool98
Re: Warped Rotors
Not true in all instances, on a single piston caliper this is not as prevalent as on dual piston calipers
Ok do me a favor and find a set of rotors that have been on a SUPERDUTY
and you think have runout!! and measure them with a set of calibrated calipers! Hmm! you might just realize that they acually can warp
06 CCLB SRW grey first mod was PSN sticker
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
fishinfool98 is offline
post #9 of 22 (permalink) Old 05-02-2011, 04:32 AM
Hood Rich
CTC DEEZUL's Avatar
Re: Warped Rotors
I'd love to see how he explains himself out of this #### storm
via Beans Toonz
DI SS Up-Pipe
GTP38R
post #10 of 22 (permalink) Old 05-02-2011, 04:40 AM
Caption This
444-4D's Avatar
Re: Warped Rotors
It is always true, the number of caliper pistons doesn't have anything to do with it.
That's easy, any of them that you are calling warped will have runout.
Where do I get a set of them calibrated calipers and how do I measure warp?
You're in over your head too.
444-4D is offline
