Can you add shakles to an existing lift? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 05-09-2008, 04:26 PM Thread Starter
BLCKOUT
bigcountry250's Avatar
Send a message via AIM to bigcountry250
I have a new set of 38x13.5 Toyo MT's on the way, I know they are gonna rub a litte with only my 6" lift. Question is can I get a set of from hangers that they use for the leveling kits, 2", and add them to get a little taller?
Will it effect enything at all? I would just get the 6" rear block from DR and put it inplace of my 4.5" rear block now to raise the rear.
I wouldn't change the shocks bc my truck never gets flexed and doesn't do ANY offroading.
2011 CC SB 6.7L Powerstroke
BLACKOUT.... gone but never forgotten!!
bigcountry250 is offline
post #2 of 10 (permalink) Old 05-09-2008, 05:01 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Can you add shakles to an existing lift?
I made a set of shackles for the Excursion with Chelseas 6" lift. Gave her about 1" more...
Joe
CSIPSD is offline
post #3 of 10 (permalink) Old 05-09-2008, 05:17 PM
Banning Smut
PTSUPERD's Avatar
Yes you can. You'll prolly need a longer pitman arm....like from an 8" kit. You will also probably need an adjustable trackbar.
Dont forget, anything over 8" is borderline for needing crossover steering.
PTSUPERD is offline
post #4 of 10 (permalink) Old 05-09-2008, 06:25 PM Thread Starter
BLCKOUT
Thats all I would really need is about 1-1.5 more inches, wanna make another set?
post #5 of 10 (permalink) Old 05-09-2008, 06:31 PM
Banning Smut
PTSUPERD's Avatar
Warrior shackles = 1.5". Easy solution. cost is about 70 bucks.
http://www.warriorproducts.com/catalog/catalog.php
PTSUPERD is offline
post #6 of 10 (permalink) Old 05-09-2008, 06:34 PM Thread Starter
BLCKOUT
Those would be easy, can I use them on the rear as well?
post #7 of 10 (permalink) Old 05-09-2008, 06:36 PM
CSIPSD's Avatar
No, the rear springs hang from the shackles, not off them...
Joe
CSIPSD is offline
post #8 of 10 (permalink) Old 05-09-2008, 06:41 PM
Banning Smut
PTSUPERD's Avatar
]Also. Just for reference, Here is 6" Pro Comp springs (same as you right?) with 3" Trailmaster hanger/shackle kit. I actually prefer more fender clearance over the stuffed look.
From WAY back in the day.
PTSUPERD is offline
post #9 of 10 (permalink) Old 05-09-2008, 08:29 PM
Layson's Avatar
Yes you can turn it into a 8 or 9" lift with shackles. You need to talk to DCspecial. He knows exactly what you need. I have talked with him about it before!
Layson is offline
post #10 of 10 (permalink) Old 05-10-2008, 01:49 AM
Evil Genius
DCSpecial's Avatar
RCD 2" hanger and shackle with an adjustable trac bar for the front.
Larger block for the rear as you mentioned.
Or you could do a smaller block in the rear and the Fabtech 3" rear hanger and shackle setup.
Without knowing the shocks you have it's hard to comment on them, rears are easy to rotate the lower mounts on the axle tube upward to compensate for the additional lift.
DCSpecial is offline
