Anyone with autometers actually have a dimmer that works? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-29-2011, 05:23 AM Thread Starter
PETE ENGR PSD
I have two from bob neither work for crap. He doesn't have an answer for why they dont so Im thinking its the dimmer knobs themselves. Does anyone have a dimmer knob that works properly?
Kevin
KEVIN
2006 F-350 Kingranch 79,XXX
TAMU_PSD is offline
post #2 of 13 (permalink) Old 04-29-2011, 05:33 AM
Spatel23's Avatar
Re: Anyone with autometers actually have a dimmer that works?
are you talking about the actual dimmer made by autometer for gauges with led lighting?
08 F350 KR CCSB SRW
DPC 2011 participant
1040hp on fuel only
FOR SALE
Spatel23 is offline
post #3 of 13 (permalink) Old 04-29-2011, 05:37 AM Thread Starter
PETE ENGR PSD
No this dimmer was sold by bob at the diesel site. Does the autometer one actually work? I'm tired of them no dimming properly so I just need one that works. And these are led .
KEVIN
TAMU_PSD is offline
post #4 of 13 (permalink) Old 04-29-2011, 06:15 AM
OBS junkie
Cat_Rebel's Avatar
I've always had them wired into the factory dimmer (OBS & SD) & never had an issue even with the LEDs. Never used an aux dimmer before. Never really messed with Auto Meters on an 05+ so can't say for sure how different they are.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
post #5 of 13 (permalink) Old 04-29-2011, 02:47 PM
Spatel23's Avatar
Ill have mine installed by the end of the day and let you know how it works.
Its only like $35.
08 F350 KR CCSB SRW
1040hp on fuel only
FOR SALE
Spatel23 is offline
post #6 of 13 (permalink) Old 04-29-2011, 02:53 PM
95powersmoker's Avatar
I have my Ultralites dim with the factory light switch also...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #7 of 13 (permalink) Old 04-29-2011, 03:19 PM Thread Starter
PETE ENGR PSD
I just dont want everything on my dash going dim at once. If I have the gauges down low, i like to still be able to see everything else without squinting
KEVIN
TAMU_PSD is offline
post #8 of 13 (permalink) Old 04-29-2011, 09:38 PM
tree trimmer's Avatar
i hooked up three autometer cobalt guages, dimmer wire tapped into the dimmer wire behind the light switch so everything would dim together. worked for about 3 months then driving down the interstate, the headlight switch shorted, a shot of smoke come out of the dash, and the whole truck went dark, headlight/dash/trailer/dome, all of it. doin 75mph down the interstate at 3 am pulling a 13k g/n, thats freaky.
i now have the dimmer wire trippin a relay to power all lighting aspects. then i got the dimmer from autometer and tapped that in.
on a side note, when i got my guages in, and tapped like the first example, i could not get them dim enough. you can also put that dimmer inline, and "dim the dimmer",
2010 f350 srw lariat
tree trimmer is offline
post #9 of 13 (permalink) Old 04-29-2011, 10:52 PM Thread Starter
PETE ENGR PSD
Okay well I see that the factory dimmer will work. But does anyone use an aftermarket one that works just as well?
KEVIN
TAMU_PSD is offline
post #10 of 13 (permalink) Old 04-30-2011, 01:16 AM
if you want it to dim with the dash, yo have to use the factory one. other wise, if its still to bright, or you want it seperate, get the autometer dimmer, and put it either in addition to, or seperate from the factory one.
