Wheel balancing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 05-08-2008, 07:26 PM Thread Starter
Bleau May
Soaggydogg's Avatar
Wheel balancing
What is everyone using to balance their aftermarket wheels and tires?
Normal inside/outside weights, stick-ons, dyna-beads or what?
02 Excursion foil delete and a Tapercore
Soaggydogg is offline
post #2 of 21 (permalink) Old 05-08-2008, 07:49 PM
fbilly420's Avatar
Re: Wheel balancing
stick ons work great on my wheels even going off road everyday and washing 1 or 2 times a week.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #3 of 21 (permalink) Old 05-08-2008, 08:00 PM
Village Idiot
southmike's Avatar
Re: Wheel balancing
my stock rims sling weights off every now and then...I am thinking about stick ons. and/ or centamatics.
southmike is offline
post #4 of 21 (permalink) Old 05-09-2008, 03:59 AM
Send a message via AIM to JohnT
Re: Wheel balancing
Stick-on style inside the rim. I think I might have lost a weight off one rim, but its time for one of my free balance and rotation's so it doesn't bother me at all.
99 PSD 4x4 CCLB
05 PSD 4x2 RCLB
JohnT is offline
post #5 of 21 (permalink) Old 05-09-2008, 04:05 AM
2nd class citizen
1snotrocket's Avatar
Re: Wheel balancing
i went stick on. on the inside of the rim. just clean the contact spot with brake clean or cleaning agent so it will stay.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #6 of 21 (permalink) Old 05-09-2008, 04:14 AM
Re: Wheel balancing
Stick-ons on the back side and NuMag in the tire.
69W900A is offline
post #7 of 21 (permalink) Old 05-09-2008, 06:54 AM
ARMY bound
Re: Wheel balancing
centramatics suck, I have not had much luck with mine
bbbxcursion is offline
post #8 of 21 (permalink) Old 05-09-2008, 07:00 AM
squeak12's Avatar
Re: Wheel balancing
I use stickons with the machine on static. Its makes it where you only put weight in the center on the wheel not inner and outer. But with my 37s, I gave up when it said more than 3 oz. and decided to just run them unbalanced.
squeak12 is offline
post #9 of 21 (permalink) Old 05-09-2008, 04:57 PM
Re: Wheel balancing
Why not? I have had good luck with mine on 35"s.
High PSI is offline
post #10 of 21 (permalink) Old 05-10-2008, 02:36 AM
Needs more hours per day
jtharvey's Avatar
Re: Wheel balancing
I was thinking about centramatics because my tires just don't seem to want to balance. I don't know anything about them though.
I did try some dynabeads on my last set of tires. Never again will I do that. They never seemed to want to balance with any kind of consistancy and vibrated a lot.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
