6.0L 2007 starts cold / no starts when hot - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 11-14-2017, 12:54 PM Thread Starter
LkidBen's Avatar
Hey guys this is my first time here I figured Iíve give this a shot because Iím running out of idea on where to look.
So my problem is, the truck will start every time when itís cold, sometime itíll take a sec or 2 longer then usual but will start runs great no miss fire no rough idle I let it warm up to itís temperature and everything is fine I can do what I need to do and I wonít have problem as long as I donít shut it off.
If I do shut it off, it will no fire back up until it cools back down.
Iíve replace every o-ring on the oil system (turbo, HPOP, Stand pipe, Dummy plug, injector, even the nipple cup ones ) and still to this point it wonít fire back up if itís warm. Iím not sure where else to look for a leak. If someone could help me out thatíd be great thanks.
LkidBen is offline
post #2 of 2 (permalink) Old 01-30-2018, 01:40 AM
Re: 6.0L 2007 starts cold / no starts when hot
i would try an IPR maybe sticking
how do you check for leaks ? do you do an air test ?
larry17 is offline
