BB Turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 08-20-2007, 03:24 AM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
BB Turbo
What companies are making BB replacement turbos other than TN and Garrett?
How do they stack up to handling boost pressures?
Will they last awhile?
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 17 (permalink) Old 08-20-2007, 04:17 AM
Banned
Re: BB Turbo
You just named both companies offering a BB drop in, and one of those is just now starting initial offerings.
The Garrett unit is tough as nails. Most BB units are. Mine has probably 4 or 5 years on it and it has been treated rough. 40-50lbs of boost all the time for the past year or so. With exhaust gas temps deep into the 1700's everytime I went WOT it was not babied. B-codes for about 2 years now.
Time will tell how the TN unit holds up, but I'm sure it will more than likely be fine as well.
Charles is offline
post #3 of 17 (permalink) Old 08-20-2007, 12:24 PM
Village Idiot
southmike's Avatar
Re: BB Turbo
garret is the common bb...tn is soon to release one after more testing .
there are others ,i think one goes by the name big bad wolf. ats has some,
isn't the h2e abb of sorts.
southmike is offline
post #4 of 17 (permalink) Old 08-20-2007, 06:41 PM
DarkShadowDiesel's Avatar
Re: BB Turbo
no, the h2e is not a bb and neither is the big bad wolf. they are both thrust bearing.
as charles said, garrett and tn make the drop in bbs with the tn being released soon hopefully.
2002 F250
DarkShadowDiesel is offline
post #5 of 17 (permalink) Old 08-20-2007, 06:42 PM
Re: BB Turbo
I think the ATS BB was the early version of what is now the Garrett?
gregrob is offline
post #6 of 17 (permalink) Old 08-20-2007, 07:46 PM
Re: BB Turbo
yup, i think they share most of the same parts, i heard something like ~65% once but am not sure
2002 F250
post #7 of 17 (permalink) Old 08-20-2007, 08:34 PM
Village Idiot
southmike's Avatar
Re: BB Turbo
how bout the ats aurora 5000? 60~70lb boost
I saw a kit a while back but they seemed to vanish
but seems like lott and bunting were looking at those a while back and the 42 was better
not sure but i thought i saw it on another forum ..dieselperformance or something like that.
post #8 of 17 (permalink) Old 08-20-2007, 08:52 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: BB Turbo
I would not buy anything from ATS...
Joe
CSIPSD is offline
post #9 of 17 (permalink) Old 08-20-2007, 08:56 PM
Hated by All
Fast_Ashley's Avatar
Re: BB Turbo
That makes 2 of us...
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #10 of 17 (permalink) Old 08-20-2007, 09:00 PM
Non Helpful Member
Deerezilla's Avatar
Re: BB Turbo
ATS=
2 fords that make no power
Deerezilla is offline
