where is this coming from? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 08-19-2007, 09:27 PM Thread Starter
DSALF250's Avatar
I installed an h2e this week and now have a bad oil leak coming from the back of the valley. I am posotive the o-rings are sealed up on the mounting plate and the oildrain tube is fine. Anyone experience this before with this set-up? Torque on plate is plenty tight.
99 F-250-SOLD
2006 Dodge Ram Big Horn Edition Quad Cab 4x4 SB, Smarty/Edge EZ, FBD 5" exhaust system HTT turbo...... and an Airdog 150 compliments of Charlie & Competition Diesel....more on the way.
502/960
DSALF250 is offline
post #2 of 14 (permalink) Old 08-19-2007, 09:38 PM
Moderator
Blowby's Avatar
Re: where is this coming from?
Spray it down with engine cleaner and start the truck up. Get a mirror back behind the pedistal and return tube.
First:
Look for oil seaping where the tube enters the plate. If this is the area check the return tube end that fits into the o-ring and make sure the tube is round and does not have any marks that allow oil to pass the o-ring. Also the tube needs to be 90 degrees to the pedistal to seal right.
Second:
If the oil is coming from the turbo mount or under the pedistal then removing the turbo or pedistal will have to be done.
Hope it's an easy tube fix.
Blowby is offline
post #3 of 14 (permalink) Old 08-19-2007, 09:40 PM Thread Starter
DSALF250's Avatar
First:
Second:
I put a brand new tube, and it is 90 deg. to the plate......Guess I will go pull it...........#$%*!!!!.............Mike, you know the torque spec for the plate?
99 F-250-SOLD
502/960
DSALF250 is offline
post #4 of 14 (permalink) Old 08-19-2007, 09:46 PM
Moderator
Blowby's Avatar
It's easy to take the tube off, also check that you didn't dislodge the o-ring when you poked it in. I always put a little lube on the out side to keep the rubber from bustin lose during insertion at extreme angles.
I don't have the tq spec's. Sorry!
Blowby is offline
post #5 of 14 (permalink) Old 08-19-2007, 09:52 PM Thread Starter
DSALF250's Avatar
Mike - way too much information..............
99 F-250-SOLD
502/960
DSALF250 is offline
post #6 of 14 (permalink) Old 08-19-2007, 11:22 PM Thread Starter
DSALF250's Avatar
Ok, I found the leak. My DI HPX gave way...Good thing I saved the plugs.
I feel so much better now. I put this on like 4 years ago so it was probably due for an updated one.
99 F-250-SOLD
502/960
DSALF250 is offline
post #7 of 14 (permalink) Old 08-20-2007, 12:56 AM
Slated4Greatness's Avatar
I thought maybe Joe helped you install it...
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #8 of 14 (permalink) Old 08-20-2007, 01:27 AM Thread Starter
DSALF250's Avatar
Joe? I think you mean Andrew.
99 F-250-SOLD
502/960
DSALF250 is offline
post #9 of 14 (permalink) Old 08-20-2007, 10:09 PM
Corona Killa
THEDIESELMAN's Avatar
Dsalf250 i thought you wanted to put a Cummins in your rig did your plans change.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #10 of 14 (permalink) Old 08-21-2007, 04:08 AM Thread Starter
DSALF250's Avatar
BIG time! I started a new business so all my funds went to that. Maybe later I will do it.
99 F-250-SOLD
502/960
DSALF250 is offline
