Fluidampr install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 08-19-2007, 06:24 AM Thread Starter
Hated by All
Fast_Ashley's Avatar
Fluidampr install
How difficult is it?? Is it worth putting the Melling pump in while your at it, or is it a pain in the ass??
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #2 of 10 (permalink) Old 08-19-2007, 03:11 PM
<- Sums it up
strokin_early_99's Avatar
Re: Fluidampr install
I don't know about the melling pump. But the dampener is not that hard. You need to take the belt, fan and shroud off. The use a dampener puller and pull it off. Put the new one on with a dampener installer. Napa wanted $165 for the tool. Auto Zone wanted $35 for the tool to buy or borrow then get your money back. It took me 2 hours and 6 beers to install mine. The hardest part was getting the shroud out without draining any coolant or taking any hoses off.
Keep Strokin'
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #3 of 10 (permalink) Old 08-19-2007, 05:29 PM
DI POWER
joediesle's Avatar
Its alittle hard to get the fan off the bitch is usally on very tight, mine took 2 people to get it off. Also u have to tq the fluidampr to 200lbs, 1 person has to stop the engine from turning why'll 1 tqs the fluidampr. Smoothed my engine big time, revs quicker too, worth doing.
01 250 sc xlt -" Forged Rods," Full Force 238/100s inj, Reg kit, Big fuel,DP F5 tunes, ATS BB turbo, ARP Headstuds, Com 910s, DI Pushrods, IDM mod, AFE Stage 2, TE2 HPOP R-IPR, BTS Trans, 6.0 intercooler, Fluidampr, HX, Cool max trans cooler, 4''exhaust & MORE.
joediesle is offline
post #4 of 10 (permalink) Old 08-19-2007, 05:41 PM Thread Starter
Hated by All
How do you go about holding the engine still while torqing the dampr???
PARIAH
2001 F-350
post #5 of 10 (permalink) Old 08-19-2007, 07:51 PM
<----Colin Banks
mattymx's Avatar
I have done it by leaving it in gear and have someone apply the brakes. But that is for a manual trans.
mattymx is offline
post #6 of 10 (permalink) Old 08-19-2007, 07:52 PM
<- Sums it up
Get the old lady to hang onto the flywheel with a flywheel turner and you torque away. Worked for me.
Keep strokin'
Early99 CC LWB 4X4
Tows like a champ!
--Lisa P.
Just sold to Larry
post #7 of 10 (permalink) Old 08-20-2007, 01:01 AM
Slated4Greatness's Avatar
You don't have to take the fan all the way off. If you just take is loose you can get in there to remove the bolts.
P.S. Don't forget to take the big thick washer out once you remove the large bolt in the middle of the old balancer. Don't ask....
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #8 of 10 (permalink) Old 08-20-2007, 01:45 AM
The LPOP is ony 4 bolts if you already have the damper off. Takes about another 5 minuets to RnR the LPOP.
69W900A is offline
post #9 of 10 (permalink) Old 08-20-2007, 01:49 AM Thread Starter
Hated by All
Thanks
PARIAH
2001 F-350
post #10 of 10 (permalink) Old 08-20-2007, 04:08 AM
Needs more hours per day
jtharvey's Avatar
Agreed. If you're already in there that far...
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
