auto to stick conversion? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 08-18-2007, 11:42 PM Thread Starter
Got 'Er Did
lownslow's Avatar
well i tried getting a response over at dieselstop but no luck and i got invited this way so i guess i will make my first post a goody
it am tired of this freewheelin automatic
i thought i'd try one but i am just not happy with one behind a diesel
so i need help and insight how to convert to a hand shaker
thanks
tanner
2009 Mustang GT Premium 5spd
BBK Long Tube Headlers and Off Road X Pipe
waiting for the squeeze
1995 F350 Crew Long 4x4 Dually
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #2 of 24 (permalink) Old 08-19-2007, 12:05 AM
Haul_n_horses2's Avatar
Re: auto to stick conversion?
thanks
tanner
What do you do with the truck? I think it is just the crappy TC/tranny that bugs you. You definitely need to sit in/drive a truck with a BTS or JW or other built tranny. World of difference.
BTS is the best mod I have done to date.
Haul_n_horses2 is offline
post #3 of 24 (permalink) Old 08-19-2007, 12:52 AM Thread Starter
Got 'Er Did
lownslow's Avatar
i havent ridden in one
but then i am lookin at the prices to get a built auto of converting to a 6 speed and unless i am overlookin something
wouldnt it be cheaper for me to convert to a manual then spending $4500 min. to get a built trans?
and i do like shifting myself a lot better
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #4 of 24 (permalink) Old 08-19-2007, 01:49 AM
Jaw-Juh Stroker
If you (like me) just don't like automatic transmissions, even a BTS won't satisfy you. Personally the fact that a transmission has to be modded to make it stand up really turns me off of them.
As for cost, the hardest thing is finding the ZF6. You can buy one online, but I can't find any prices at the moment. Prices for the ZF6 on a gasser are around $3,200. I'm sure it's a little more for the diesel. Then you'll need a clutch and perhaps a new flywheel. I believe the auto uses the same transfer case, but I really couldn't say.
As for fab work, you'll have to cut and weld a bit on the sheet metal in the cab floor, as the ZF6 is taller than the slushbox. You may need to elongate or shorten a drive-shaft or two, I really couldn't say.
Your best bet is to find a wrecked truck at a junk yard, buy the transmission, clutch, flywheel, clutch pedal assembly, drive-shafts, and maybe transfer case. The actual work isn't all that hard, but there's plenty of parts to get. You could offset this cost of course by selling your automatic transmission. If you get a good price on everything, you might get out of this with your wallet only a couple grand lighter.
2002 F250 4x4
T-444E 6-speed
Alan Hicks is offline
post #5 of 24 (permalink) Old 08-19-2007, 02:04 AM Thread Starter
Got 'Er Did
lownslow's Avatar
that was the plan
when i lived in sidney mt i worked for a guy that bought wrecked super duty's and rebuilt them
and he was a strictly auto man so if a six speed came in he most likely converted to an auto
so i am hoping that i can swing a deal with him and swap most parts with him
so you have to change the floor pan AND do further cutting/welding to cab itself?
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #6 of 24 (permalink) Old 08-19-2007, 02:45 AM
Banned
I gave 1900 dollars for the brand new crate ZF6 in my truck. You can pick up a reman for about the same price usually.
Call Southern Gear in Atlanta Ga and see what they want for a ZF6 reman. Be aware that there will likely be a core charge of around 500 bucks as well.
If you get serious about it let me know as I can tell you EVERY little thing that will have to be changed and I personally have a couple harnesses you might want as well as a spare clutch pedal assembly.
Maybe we should trade.....your auto for my manual
Although I don't think I've got the energy for another project right now.
Charles is offline
post #7 of 24 (permalink) Old 08-19-2007, 03:12 AM Thread Starter
Got 'Er Did
lownslow's Avatar
whenever you are ready charles
let me know
Powerstroke
Auto
4 inch MBRP
lownslow is offline
post #8 of 24 (permalink) Old 08-21-2007, 12:44 AM
Banned
How many miles you got on the auto, and what's its condition?
I can't believe I'm even considering this right now...
Oh, and how far do you live from TN? No that's not Turbonetics
Charles is offline
post #9 of 24 (permalink) Old 08-21-2007, 02:57 AM
Corona Killa
THEDIESELMAN's Avatar
This would be a crazy swap if you guys end up doing it and how long do you think it would take you.
2007 DODGE 2500 CREW CAB 4X4 5.9 LITER CUMMINS
2002 FORD F-250 CREW CAB 4X4 POWERSTROKE
THEDIESELMAN is offline
post #10 of 24 (permalink) Old 08-21-2007, 12:05 PM
Banned
I don't think it would take all that long on my end at all. Basiclally just the same as a clutch swap for me, but just putting back a flexplate and an auto instead of the manual. When I go this route it will be controlled via a stand-alone module with a joystick, so not harness issues for me.
I think it could happen in a weekend. The only thing that is a variable is how receptive his underbody will be to the top of the ZF6, and the hole for the shifter in his floor.
Just depends on if he would be willing to meet in TN at swamps to do it. I know my way around that shop blindfolded and their tools, lifts and such make this type of thing a breeze.
Not to mention I could prooobably get em to let me use a couple bays for a weekend...
Charles is offline
