van turbo? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-16-2011, 12:36 AM Thread Starter
PoweR_STOKED_Bryan's Avatar
Send a message via AIM to PoweR_STOKED_Bryan
van turbo?
hey guys. ive got a question about turbos. i just bought a 2001 f-350 with an afe stage 1 intake, php chip, 4 inch straight pipe to 5 inch miter cut stacks. i am experiencing some surge when i hammer on it a little bit. i was looking at buying the ATS ported housing because its an almost guranteed fix. a friend of mine told me that the van turbo is a great drop in replacement that will provide better performance, cure surge and lower egts....plus you can find one for a couple hundred bucks more than just the housing. is this true? thanks for the help!
PoweR_STOKED_Bryan is offline
post #2 of 9 (permalink) Old 02-16-2011, 12:42 AM
Re: van turbo?
Van turbo would be a good upgrade. Just get a van turbo adapter and a wicked wheel and you will have no more surge.
2000 F-350 Crew Cab - 7.3L Turbo Diesel, .10 Over Block w/ Machined Mahle Pistons, Cryo'd Forged Rods, Melling LPOP, Fully Balanced Engine, Rosewood 250cc/100%, BatMoWheel'd 1.15 38r, SRP1, ITP RR, 910's, DI Pushrods, ARP Studs, Walbro Pump, BDP Live Tuned, and BTS Converter+VB+Pump Mods.
545rwhp/1,243rwtq - w/o Built Engine and BatMoWheel
Wickky is offline
post #3 of 9 (permalink) Old 02-16-2011, 12:47 AM Thread Starter
Re: van turbo?
i found a turbo with 90K miles and a wicked wheel for 300 bucks...good deal?
post #4 of 9 (permalink) Old 02-16-2011, 12:55 AM
white7.3's Avatar
Re: van turbo?
Van turbo is a drop in replacement you just need to get the adapter for the exhaust housing.. i dont know if in the long run if its cheaper than the ats housing but it is a good option to cure surge issues. I think all said and done after i had mine done ive got about 400$ in it after selling my stock turbo.. only difference in the van turbo and a stock turbo is the exhaust housing size. stock is .84ar and van turbo is 1.15ar and non wastegated.
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
6.0 I/C Van Turbo & WW
6637 Intake 5" Exhaust
Custom RR Fuel System
05 Grille/08 Center Console
Raptor 372 w/ Toyo Open
Country AT2 35/12.50
white7.3 is offline
post #5 of 9 (permalink) Old 02-16-2011, 12:59 AM
white7.3's Avatar
Re: van turbo?
If i were you i would rebuild it before installing it..
Beans Diesel Performance - 99-03 Power Stroke Stock Turbo Rebuild Kit (Powered by CubeCart)
And heres the link for the adapter
Beans Diesel Performance - 99-03 Power Stroke Van Turbo Adapter Flange (Powered by CubeCart)
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
white7.3 is offline
post #6 of 9 (permalink) Old 02-16-2011, 01:01 AM Thread Starter
Re: van turbo?
do they not last as long or something? i mean the ATS housing is a $430 part that shouldnt need "maintenence". im not looking to build this truck or anything. i just want a reliable, daily driver, and towing truck.
post #7 of 9 (permalink) Old 02-16-2011, 01:12 AM
white7.3's Avatar
Re: van turbo?
Yeh should last as long as any other turbo. Ive not had a problem yet out of mine and ive put around 15k on it. I rebuilt mine myself and installed the WW and non ebpv pedistal.. Should hold up just fine....
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
white7.3 is offline
post #8 of 9 (permalink) Old 02-16-2011, 01:35 AM Thread Starter
Re: van turbo?
ok cool. spools up just as fast as stock? thanks for the responses. if i can buy one for a decent price i probably will.
post #9 of 9 (permalink) Old 02-16-2011, 01:42 AM
white7.3's Avatar
Re: van turbo?
No it spools up slower than the stock turbo due to the larger exhaust housing. Its pretty laggy on the low end, mine spools up i think around 1600rpm or so.. but once it spools egt's barely go up compared to the stock superduty turbo.
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
white7.3 is offline
