can i run two donaldson filters - Page 3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #21 of 23 (permalink) Old 01-27-2011, 01:00 AM
theSLEEPER's Avatar
Re: can i run two donaldson filters
Where is your filterminder positioned?? Does your buddy have the exact same air filter setup?
theSLEEPER is offline
post #22 of 23 (permalink) Old 01-27-2011, 03:16 AM Thread Starter
jewettb's Avatar
he has the same tymar as i do but everything else is stock turbo injectors ECT. it is in the elbow right before the filter.
1999 F250 sc 4x4 ccv, tymar intake,4 in turbo out, gtp 38r 1.15 ar, beans stage II injectors, ts preformance chip, boost fooler,stelth srp 1 hpop, walbro 255 fule pump, auto meter cobalt gauges,live tuned by jonathon at beans diesel.459.1 HP
jewettb is offline
post #23 of 23 (permalink) Old 01-27-2011, 03:24 AM
Village Idiot
southmike's Avatar
Depends on the filter.. I suppose.
I run two works great. But I believe the initial problem was I used a three inch PVC pipe for a conector. My four inch wye won't set the minded even with one covered. Though swamps has a cool video of a pipe getting sucked flat behind a tymar, something was not flowing enough.
southmike is offline
