Warranty question/ Rebuild cost - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 34 (permalink) Old 08-15-2007, 10:50 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Nothing more, nothing less
What is the warranty of the Garrett "PowerMax" GTP-38r?
What is the cost to rebuild a Garrett "PowerMax" GTP-38r?
Really, that is all I am asking.
Joe
CSIPSD is offline
post #2 of 34 (permalink) Old 08-15-2007, 11:18 PM
Re: Warranty question/ Rebuild cost
I don't know what the warrenty is. Rebuild cost is high. If you don't need wheels, the only way to "rebuild" it is to replace the cartridge. IIRC you can get the cartridges for around 675-875 depending on the vendor. Those are old prices, they may be less now you'd have to check with a Garrett dealer to be sure.
69W900A is offline
post #3 of 34 (permalink) Old 08-15-2007, 11:37 PM
Tim @ P.I.S.'s Avatar
I don't recall what al was included but i was quoted like $1100.
Tim @ P.I.S. is offline
post #4 of 34 (permalink) Old 08-16-2007, 12:07 AM
Non Helpful Member
Deerezilla's Avatar
I know you think i'm some dumb farmer that don't know a thing.
But you have a great turbo man in Or. call Bell turbo I talk to him all the time I even have a turbo with him right now . I would go by his shop and ask him to look at it. But don't talk to much he can be a CRAB lol
2 fords that make no power
Deerezilla is offline
post #5 of 34 (permalink) Old 08-16-2007, 12:26 AM
coope3's Avatar
I found this on another garrett turbo
Garrett GT4088R - AKA GT40R
Dual Ball Bearing
Compressor Specs
4" Inlet / 2.5" Outlet
.58 a/r Housing
88mm - 52 Trim Wheel
Turbine Specs
77mm - 78 Trim
3" - V Band Exhaust
Supports 700+ HP
1 Year Manufacturer Warranty
Does NOT cover:
Oil Starvation
Oil Contamination
Improper Installation
Foreign Object Damage
Warranty Terms: READ BEFORE PURCHASING
If there is a problem with your turbo:
The turbo must be sent to our Garrett Performance Distributor
Customer is initially responsible for all shipping charges
If turbo is deemed to have a factory defect, return shipping will be at no charge
*If your turbo needs to be sent in for inspection, we cannot send you another turbo for your vehicle to use while waiting for your's to be serviced. You should expect at least 5-10 working days for warranty inspection/repair. These terms are non-negotiable, and will be strictly upheld.
02 F350 CC 4x4, Common rail, 90hp injectors, Hellman intercooler,studs,twin cp3s,64/71/14 HTT turbo, HTT manifold,maxspool cam,Smarty POD,TS MP8,ported head, BTS tranny,PCS tranny controller,Airdog,Trac bars
2015 F250 CC 4x4 6.7 powerstroke stock
coope3 is offline
post #6 of 34 (permalink) Old 08-16-2007, 01:13 AM
That is a fairly standard warranty by OEM turbo mfg's. High performance places such as TN generally have a better warranty. Even Ford was required to send warranty turbos in to Garrett for evaluation. I've had to do the same with CAT, Holset, BW, KKK, Switzcher and Rotomaster. Garrett has had pretty much the same warranty since they were Airesearch.
69W900A is offline
post #7 of 34 (permalink) Old 08-16-2007, 01:48 AM
Banned
FWIW, when you swap out the CHRA in a ball bearing turbo (or any turbo for that matter) you have a NEW unit. Housings do not wear out. That is not a rebuild, it's new. You cannot sell a balanced, NEW CHRA without it including the compressor wheel. All you do is bolt your housings back on it and enjoy.
You can have a NEW CHRA for 1000 or less. It's really not cost prohibitive. Especially considering that you just don't actually ever need it anyway. I doing mine in the near future because it's got a bent turbine blade, and I ran it at over 50psi for about 3 months. Now with the GT47 right around the corner awaiting any possible debris, it's just not worth it to chance with the bent blade and all.
Charles is offline
post #8 of 34 (permalink) Old 08-16-2007, 04:16 AM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
MY suggestion is to buy a TN turbo as that is the best turbo in the whole wide world with the best warranty to boot.
ITP is also the best place to buy a TN turbo, Great dealer with the best reputable service.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #9 of 34 (permalink) Old 08-16-2007, 04:39 AM
Drinking pink again?
TerminatorEngineering is offline
post #10 of 34 (permalink) Old 08-16-2007, 06:44 AM
PwrStrokinDually's Avatar
Send a message via AIM to PwrStrokinDually
Pius is a great guy. Whenever I'm in the area now I stop by and he takes a break and has me sit down with his wife, son, and dog for a cup of coffee. Even gave me a Bell Turbo hat that he forgot to give me when he rebuilt my turbo.
Danny Om
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
Fully built motor w/ B-codes, GT42R, and Terminator w/ Remote IPR HPOS.
PwrStrokinDually is offline
