S471 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-17-2011, 07:21 AM Thread Starter
Oooo, White Lightning !
Dieselboy's Avatar
S471
Looking at upgrading my H2E to a S471.. Anyone bought from these guys before ?
http://www.agpturbo.com/product.php?...cat=334&page=1
What would be the best A/R choice ?
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #2 of 4 (permalink) Old 01-17-2011, 11:38 AM
Crazy Redneck
UNCOOL's Avatar
Re: S471
The 1.1 that it comes with. That turbine wheel is a bit small to try and run a tighter housing.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #3 of 4 (permalink) Old 01-18-2011, 06:07 AM Thread Starter
Dieselboy's Avatar
Re: S471
Will my oil drain and feed lines off the H2E transfer over ?
And how would I mount my intercooler pipe to the comp housing ? Looks like it has a flange on this one
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
post #4 of 4 (permalink) Old 01-18-2011, 12:44 PM
Busy Busy
Marty's Avatar
Re: S471
I would swap over to a -6 line now, that S471 should have a 1/4" NPT hole for the oil there. At least everyone I've ever used did.
Also, you need to get a 3" Vband and O ring. Weld that on your H2E pipe. Mock it up first with the bottom boot NOT clamped down and then mark the tube and Vband with a Sharpie. Take it over to the welder and tack it together. Reinstall with bottom boot and Vband clamp at the turbo and make sure it's tits. It won't be a straight weld on... it will have to be angled and turned just alittle being that the H2E pipe leaves a little to be desired as it is. You may even have to cut the tube near the top and use a boot/strap to hold it together or make your own extension of the piping.
Anyway once that's done... finish welding it and you are done. Weld in short beads to avoid warpage.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
