?about a rearend fix - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-15-2007, 06:42 PM Thread Starter
Stupid Kid
Last year I messed up my rearend housing at a pull and it spun the pumpkin so that it was pointed upwards. Well I don't want it to happen again so I am going to weld the castiron pupmkin to the mild steel axle tubes. I lan on doing probably like 3 1.5 inch stiches. Has anyone here done this? I have see one or 2 in pics that were welded, but I can not remember who did it. I plan on cleaning it real well and removing a small amount of material for a root pass then I am going to do a wider cover pass on top of that. I am using a nickel iron alloy electrode as well. Just seeing if anyone has any tips on doing this.
thedieselkid is offline
post #2 of 5 (permalink) Old 08-15-2007, 07:05 PM
Transmission Junkie
Re: ?about a rearend fix
I have done it, on trucks and our drag cars that make a bunch of power. We weld them completely around. You are on the right track though. Sounds good, do it to it.
02Bluestroker is offline
post #3 of 5 (permalink) Old 08-16-2007, 12:01 AM
I've done it on several different types of axles. I like to preheat a bit, espically on the pumpkin and make several passes. No big deal, just takes a bit of time.
69W900A is offline
post #4 of 5 (permalink) Old 08-16-2007, 01:25 AM
10.61 @ 128 MPH
Powersmoker's Avatar
Send a message via AIM to Powersmoker
can a standard mig welder do this job?
2000 F-250 Regular Cab
1069 RWHP 1768 Torque
10.55 @ 129 MPH NOS
2000 F-350 ECLB DRW
Tow Rig
Murff Racing Twisted Diesel
Empire Diesel DieselSite
Swamps Diesel
Powersmoker is offline
post #5 of 5 (permalink) Old 08-16-2007, 01:34 AM
If you have mild-steel wire no.
I wouldn't recommend using a wire feed for that application anyway. You'll get a better product using a good rod for joining cast iron to mild steel pipe and preheating the pumpkin.
69W900A is offline
