Rebuild Update - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 102 (permalink) Old 01-13-2011, 01:35 AM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
Rebuild Update
#7 got sleeved today. By the end of the week, all 8 will be getting 20 over pistons. The heads have been cleaned up and new valves, seats, and comp 910's are going in along with studs once the short block gets back together.
HPOP is sent off to Joey for modding. DP chip is shipping out for updated tunes to accomodate a JW valve body and ARI TC that I installed this past weekend, Casserly's 238/100's, and a 38r that arrived today.
Waiting in the garage is a new black CPS, Bellowed up Pipes and a Walbro 392fuel pump(next to get installed).
I have the engine bay totally cleaned, repainted, and ready.
I am turning the corner on this project and ready to start to see some progress. I can only dream of how it will drive compared to what I have in my current sig.
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #2 of 102 (permalink) Old 01-13-2011, 02:19 AM
Re: Rebuild Update
I'll be following your thread. I'll be picking up my mtr this week from the machine shop. Block just needed honing, all new valves, 910 springs, polished crank, New pistons and cam bearings and brass freeze plugs. Rebuilt rods. I also had it balanced. Are you welding your piston squirters??? Now I have to start saving for the injectors and turbo and the list goes on. What it boils down to now is about another 3-4k, probably more.
oldwood is offline
post #3 of 102 (permalink) Old 01-13-2011, 02:24 AM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
Re: Rebuild Update
Tell me more about doing this please.
post #4 of 102 (permalink) Old 01-13-2011, 02:43 AM
Re: Rebuild Update
Well you here about the horrow stories about the oilers falling out into the oil pan. I'm going to find a welding shop with a Tig welder to weld these up. While you have the mtr. apart whats another few dollars for the added security. My machine shop bill was 1100.00+. What did you spend?
oldwood is offline
post #5 of 102 (permalink) Old 01-13-2011, 12:37 PM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
Re: Rebuild Update
Thanks, I will check into that. I am having the long block done completely locally so I go down there often to visit with him and we discuss options like the sleeve, studs and springs, or cleaning out the heads. I bought the studs and springs and took them down there and he is buying everything else. My bill should be 2-3k down there. I will have 8k in the whole project in the end but I am also selling off parts I don't need and I bought 3 motors(2000 model) to take parts off of or sell. I trimmed my injector bill by sending in extra cores. I hope to only have around 6k out of pocket once I am completely done.
In a weird way according to my wife, I am really enjoying this
To get my truck in the garage, I used 2 x 4's and sheets of OSB to build around the 5' of the truck that stuck out so I had room up front to work and that was after I took air out of the tires to get it under the door due to the 4" lift. I keep waiting for the building inspecto to stop buy,
post #6 of 102 (permalink) Old 01-13-2011, 05:57 PM
Village Idiot
southmike's Avatar
Re: Rebuild Update
hope to hear some good results.
my ari tc came in but is sitting in its box on the shelf till i cand do the vb and install them or have them installed..
southmike is offline
post #7 of 102 (permalink) Old 01-13-2011, 07:28 PM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
Re: Rebuild Update
I wondered about you and the ARI. I have done some research and there are some guys running them that like them. A couple of years ago, they were $500 but I haven't read anyone bashing them. The VB was easy but quite a mess.
post #8 of 102 (permalink) Old 01-13-2011, 07:33 PM
Village Idiot
southmike's Avatar
Re: Rebuild Update
the tc is what spooks me...especially after a thread i saw in the tranny section about a guy that f'd up his clutches and a pump, cause his wasn't seated fully.
I dug and dug looking for bad reviews on the ari found none....hopefully i wont be the first..
post #9 of 102 (permalink) Old 01-13-2011, 08:07 PM
Re: Rebuild Update
Kila,
Quick question, why run a modded 17* pump when its just a few hundred more for an SRP1? When I talked to Jacob at BDP and told him I wanted new tunes for my 250/100's and modded 17* pump he said not to even bother really with modding the 17*. He told me to run my stock pump and he would send out tunes for that till I had enough cash to get the SRP1 and then he would send out tunes for the SRP1. Since he told me that I ordered the SRP1 and will be running it with my new setup that is going on next week.... any reason why you are spending all that money and not going with the SRP1 or Adrenaline?
2000 F-350 Crew Cab - 7.3L Turbo Diesel, .10 Over Block w/ Machined Mahle Pistons, Cryo'd Forged Rods, Melling LPOP, Fully Balanced Engine, Rosewood 250cc/100%, BatMoWheel'd 1.15 38r, SRP1, ITP RR, 910's, DI Pushrods, ARP Studs, Walbro Pump, BDP Live Tuned, and BTS Converter+VB+Pump Mods.
545rwhp/1,243rwtq - w/o Built Engine and BatMoWheel
Wickky is offline
post #10 of 102 (permalink) Old 01-13-2011, 09:14 PM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
Re: Rebuild Update
Originally Posted by Wickky View Post
Kila,
2 reasons really, from what I have read, I assumed a good 17* would fit my needs but maybe I am wrong there.
Also, with my other motors came some trade value so I was able to work out a trade with Joey and only pay shipping one way.
Would I be wise to look at an adrenaline or the like due to the 238's?
