What can I expect? Help. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 01-11-2011, 12:51 AM Thread Starter
Single Cabs Rule!
sikksinglecab513's Avatar
Question What can I expect? Help.
Hey guys, I'll soon be starting on my single cab pretty soon. Right now I'm mostly consentrating on the looks of the truck, seeing that it looks like a stock work truck right now lol
But late on I plan on taking my TS chip to PHP and having them reburn the chip with the tunes I want. I definately want the 140 tune. I was also planning on a CFM Intake manifold, Intake, and the wicked wheel for the turbo. I already have a 4in single stack exhaust system (with downpipe) on the way. What I'm asking is, What numbers should I be expecting with these parts?
Another thing I would like to ask is what else can I add performance wise since I'm on a budget?
This is a project that me and my friend SparkZ03DMAX (guy with a Duramax ) was going to be working on.
2001- Ford F250 7.3 Powerstroke Single Cab 2wd.
All Stock BUT with TS 6 position chip.
Rims and 05' Front End on the way!!
Way more to come!!
ACR MEMBER #24
sikksinglecab513 is offline
post #2 of 23 (permalink) Old 01-11-2011, 01:02 AM
Re: What can I expect? Help.
280?
02 f250
countryboyrob is offline
post #3 of 23 (permalink) Old 01-11-2011, 01:08 AM
vanderchevy18's Avatar
That's actually exactly what it'll make I think. I had the exact same stuff on mine almost. I did an aih delete and had a turbo master wastegate. 280 is exactly what I dyno'd at.
I would say save the money on the intake, do an aih delete, and get a TM wastegate.
Chris
99.5 F250 CCSB 4X4 Auto- Bunch of stuff.
Irate Diesel Performance
1987 Mazda B2600 rclb with 2.3l 4D55T turbo diesel 4x4 5 speed manual trans. Being worked over with Irate magic. Nick named The Beast.
08 Kawasaki Brute Force camo 4x4- AMR 730xx big bore kit and bunch of other stuff. Nick named Excessive Force!!
vanderchevy18 is offline
post #4 of 23 (permalink) Old 01-11-2011, 01:11 AM
riverjet
Don't waist your cash on the cfm intake.It will not do anything much for power.Start with good tunes and intake.Afe stg2 or Ford AIS are good.WW wheel may cure surge but won't do anything for power.Save your money for good injectors and turbo and spend time on here "researching".
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
post #5 of 23 (permalink) Old 01-11-2011, 01:27 AM
HP Junky
Have fun with your build, those little regular cab 2wd trucks are fun. I've had a blast building mine...
RockinJW is offline
post #6 of 23 (permalink) Old 01-11-2011, 01:31 AM
twelch3's Avatar
You need egt,boost, & trans temp gauges if you're going to chip it.
They should come first so you know what's going on under the hood.
Good luck.
E99 f250,10" lift,22" hostages wrapped in 37" kuhmo MTs,05 face,08 tail,console & diff cover,ranchhand f&r bumpers,diy rr fuel,adrenaline,autometer phantom IIs,PMT2 with DI tunes
,sinister 5/8"straw,DI Stallion tc &bts vb,6" mbrp black stacks soon to have:238/200s & new turbo,amp steps...
twelch3 is offline
post #7 of 23 (permalink) Old 01-11-2011, 01:32 AM Thread Starter
Single Cabs Rule!
Dude I idolize your truck. Your truck is amazing!
Way more to come!!
ACR MEMBER #24
post #8 of 23 (permalink) Old 01-11-2011, 01:33 AM Thread Starter
Single Cabs Rule!
Good luck.
I'm planning on getting a set of Glowshifts soon
Way more to come!!
ACR MEMBER #24
post #9 of 23 (permalink) Old 01-11-2011, 01:33 AM
HP Junky
Thanks...the sky is the limit man
Check out my webshots for all hte photos of the build process
Project Race Truck pictures, photos, and videos, from entertainment on webshots
RockinJW is offline
post #10 of 23 (permalink) Old 01-11-2011, 01:43 AM
Drink til she's cute
Thuglike's Avatar
Performance and budget do not go together when modding a 7.3.
Being that it's a single cab a 300-330 hp build would be a real fun ride.
Intake, exhaust, stage 2's and tunes would be a nice little rig.
Throw on a water kit to keep her cool and your good to go
2008 F-250: High Powers / Dual K16 / 60% Nozzles
ELITE
NO LIMIT
SWAMPS
GEARHEAD
INNOVATIVE
Thuglike is offline
