7.3 high idle mod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 01-10-2011, 05:19 PM Thread Starter
bring the chain
kyle43335's Avatar
7.3 high idle mod
i have a early build 7.3. whats the procedure for wiring up the high idle mod? the truck is a rollback,and the bed is stuipd slow at idle. thanks.
kyle43335 is offline
post #2 of 17 (permalink) Old 01-10-2011, 08:28 PM
Yup it's me!
GTwho?'s Avatar
Re: 7.3 high idle mod
For your application I'd just pop for an AIC. You can find them on e-bay for a pretty decent price. The functions that it has will make operating a rollback so much nicer than trying to jimmy something together. What year is your truck?
'96 F-250 Extended Cab, long box 4X4, 4" lift, 35" tires
Injectors,GTS Motorsports
Crower rods, H11 Head studs, Cam,DIGen II HPOP, chip-Swamp's Diesel
Chip Live Tuned from PHP
TransBTS
Ceramic Coating from Performance Coatings in Auburn, WA
Sponsred by Nitrous Outlet[email protected] in 1/4 mi!
466hp #2 only 806hp NČO
GTwho? is offline
post #3 of 17 (permalink) Old 01-10-2011, 09:38 PM
Work in progress!
Big Calo's Avatar
Get a chip with high idle.
Southern lights!!!
My big truck Early 99
(Currently trying to unfinance!)
Foil delete
5" SS Magnablows Straight Pipe
Adrenaline HPOP
AFE Stage II w/Progaurd 7
D66 Turbo
Autometer Guages
Beans 6po chip
Full Force 250/100s
CCV mod
Big Calo is offline
post #4 of 17 (permalink) Old 01-10-2011, 09:46 PM
Caption This
444-4D's Avatar
https://www.fleet.ford.com/truckbbas...new99.html#pto
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #5 of 17 (permalink) Old 01-10-2011, 10:20 PM
Yup it's me!
GTwho?'s Avatar
Personally I think wasting a program on high idle is kind of dumb. Especially when you can have it the programing customized to only idle high at low EOT. But for runing a PTO etc. like the OP is doing the auxilary idle controller (or APCM as described in the above link) IMHO is by far the best option as there are much more functions and settings with it that will work much better than just having a high idle position on a chip.
TransBTS
GTwho? is offline
post #6 of 17 (permalink) Old 01-10-2011, 11:01 PM
Powerstrokin'
cw96stroker's Avatar
Well its pretty handy at times when your pickup is already warm like jumping off another vehicle or keepin the ac cool in the heat at idle... I personally dont think it is "dumb"..
2001 Platinum with sum stuff done
1996 F250 I solded it
2008 lifted duramax dually
Originally Posted by NE-STROKE View Post
Be a real man. Stop. Pull over. Then throw a stick in his spokes if you are that upset.
cw96stroker is offline
post #7 of 17 (permalink) Old 01-10-2011, 11:09 PM
Work in progress!
Big Calo's Avatar
Out of a 6-po chip I only use 2 95% of the time. Heavy tow and Hot tune. Could get away with just one but I like the heavy tow because I have the fuel pulled way back.
So the high idle is far from useless IMO.
Southern lights!!!
Foil delete
Adrenaline HPOP
D66 Turbo
Autometer Guages
Beans 6po chip
Full Force 250/100s
CCV mod
Big Calo is offline
post #8 of 17 (permalink) Old 01-10-2011, 11:20 PM
Yup it's me!
GTwho?'s Avatar
When the SD's have a function to raise the idle anyway what's the point? But for this application has much more options.
IMHO all you need is 3 positions. stock, tow, all she's got. With the exception of if you're running spray or propane, water/meth etc then you may need to have a tune for those. The rest of what you need should be able to be built into the programing. Like the high idle on a cold engine. My idle starts around 1100 when I first fire it up cold. Then come down to 703 once the EOT is up to operating temps.
TransBTS
GTwho? is offline
post #9 of 17 (permalink) Old 01-10-2011, 11:32 PM
Mtack's Avatar
It works great for jump starts.
Matt
E99 F350 ECSB SRW 4x4 ZF6 3.73 Adrenaline HPOP, chip, tymar
Mtack is offline
post #10 of 17 (permalink) Old 01-11-2011, 12:21 AM
Yup it's me!
GTwho?'s Avatar
The AIC or high idle on a chip? The AIC has a charge protect feature on it so if you are jump starting something, runing a winch or what ever it will raise idle to maintain voltage. Works great!
TransBTS
GTwho? is offline
