Turbo up grade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 48 (permalink) Old 01-07-2011, 06:49 AM Thread Starter
Homesteader's Avatar
Turbo up grade
When up grading a stock turbo... do you up grade turbine housing or exhaust side ?
Homesteader is offline
post #2 of 48 (permalink) Old 01-07-2011, 08:22 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: Turbo up grade
both.. it depends on what your looking for...
Ron's power stroke is offline
post #3 of 48 (permalink) Old 01-07-2011, 08:22 AM
Metal - It kicks your ass
Re: Turbo up grade
Either way... You can upgrade intake side for surge control, or exhaust side for surge control, lower drive pressures, lower egts, and better spool characteristics.
Modded L99
dirtboy25 is offline
post #4 of 48 (permalink) Old 01-07-2011, 12:48 PM
< wish it was mine
Stroken7.3's Avatar
Re: Turbo up grade
I've got a ported shroud housing, wicked wheel, turbomaster wastegate and a 1.0 exhaust housing on my stock turbo. I should've saved all that money and put it twords a 38r, H2e or QSSB set up.
2001 F-350, Auto, No Limit Tunes, Autometer Ultra-lite gauges.
Stroken7.3 is offline
post #5 of 48 (permalink) Old 01-07-2011, 05:05 PM
Re: Turbo up grade
Turbomaster question....Is it worth it?
It can be reused with the 38R...I have to remove the turbo and plan on a non-epbv pedistal...figured I add a turbomaster to the mix (both re-usable if/when a turbo comes along).
1999.5 F350 SuperCab, Auto, 4x4, 3.73, PHP tunes, PI Stallion, Tri-something-olator, Hutched/Harpooned, 6637, CCV, IAH delete, MBRP 4", Evans, 203 T-stat, Japanese drain valve, dyna-beads, 70K
two-rocks is offline
post #6 of 48 (permalink) Old 01-07-2011, 05:17 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Turbo up grade
Yup... I could have had twins with the ammount of money I had wrapped up into turbos... and turbo parts.
Turbomaster will fit on any wastegated drop in turbo for the 7.3... I loved mine!
Joe
CSIPSD is offline
post #7 of 48 (permalink) Old 01-07-2011, 10:47 PM Thread Starter
Re: Turbo up grade
What is a turbo master ?
post #8 of 48 (permalink) Old 01-07-2011, 10:49 PM Thread Starter
Re: Turbo up grade
So its not worth to mod your stock turbo ?
Isn't still less than a 38r ?
Looking for turb upgrade or turbo soon .
post #9 of 48 (permalink) Old 01-07-2011, 10:57 PM
CSIPSD's Avatar
Re: Turbo up grade
1999.5-2003</br>Ford 7.3L PSD</br>Wastegate Controller
Depends... If your just looking to get rid of surge, ATS housing...
Anything more then that, go with a 38r... D66... H2e or like...
Joe
CSIPSD is offline
post #10 of 48 (permalink) Old 01-08-2011, 01:34 AM
Caption This
444-4D's Avatar
Re: Turbo up grade
Screen Door Gate Spring 13/32 Diameter # LR102 by World Wide Sourcing
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
