Exhaust ???? - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 16 (permalink) Old 01-16-2011, 09:49 PM
Black Stroker
whytry's Avatar
Re: Exhaust ????
Originally Posted by Comp7.3 View Post
they dont make a 5" dual setup....
Why don't they?
Matts tunes
Exhaust
K&N
Nozzles
A1000 fuel system
whytry is offline
post #12 of 16 (permalink) Old 01-17-2011, 02:20 AM
TARM's Avatar
Re: Exhaust ????
Originally Posted by Homesteader View Post
I had to cut and also bend one pipe . Its still a little lower on one side but way better than what it was . I like the way Diamond mounted on my 450. Hangers arent welded to pipe,you can get it to how you want it to sit.
How did you bend a 5" pipe?
TARM is offline
post #13 of 16 (permalink) Old 01-17-2011, 06:11 AM
Homesteader's Avatar
Re: Exhaust ????
It was a 4" pipe . We are very limited here on resources,I had to use a torch to heat it up.
Homesteader is offline
post #14 of 16 (permalink) Old 01-17-2011, 10:05 AM
TARM's Avatar
Re: Exhaust ????
I did the same thing but it was only to dent in a up pipe a bit to clear the corner of the head. Think my up pipe flange was a bit boogered striaght from Diamond. It was not on stiraght or smooth but a bit canted. REally screwed up the install but by the time you realize it might be a good idea to just send it back you have already modded it to the point you cannot. I am ending up having to use a small piece of flex to get the line going rearward I need or would have to pull the uppipe cut it, rotate and reweld. A 2' piece of flex is the easy answer. Still pisses me off a bit.
TARM is offline
post #15 of 16 (permalink) Old 01-17-2011, 04:18 PM
TARM's Avatar
Re: Exhaust ????
Meant down-pipe not up-pipe.
TARM is offline
post #16 of 16 (permalink) Old 01-17-2011, 05:04 PM
Re: Exhaust ????
The problem my friends truck had was both exits,I think the left side was the worse.
