DIY intake w/Donaldson filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 01-03-2011, 01:53 AM Thread Starter
ByrdDog's Avatar
I recently got a donaldson air filter (pn 085011 I think?) that is supposed to be the same as the napa 6637 to replace my k&n. My question is: the base of the filter (where it fits onto the intake tube) is a hard plastic instead of rubber,so I don't think a clamp will work;; how do you secure it to the intake tube?
2004 F350 CCLB 4x4 Dually - EGR Delete, Coolant Filter, 5" Exhaust, Evolution tuner/monitor, Leveling kit & 33's
1960 F250 4x4 - 400/C6
ByrdDog is offline
post #2 of 8 (permalink) Old 01-03-2011, 01:55 AM
JimTJr's Avatar
Re: DIY intake w/Donaldson filter
A 4" piece of exhaust will stuff in there VERY TIGHTLY,, then a constant torque clamp, (like the CAC pipes have) will tighten on it and hold it better. In fact, you may need to "Grease" the pipe a little....
*48* Jim T. 2011 F-350 Lariat, CC, LB, SRW. White Platinum Metallic Tricoat. Black leather seats, I probably wont have*PMS,, with this one, at least no major attacks of it!
JimTJr is offline
post #3 of 8 (permalink) Old 01-03-2011, 01:55 AM
Metal - It kicks your ass
I just used a hose clamp and tightened the piss out of it... Seems to work pretty well for me.
Modded L99
dirtboy25 is offline
post #4 of 8 (permalink) Old 01-03-2011, 03:21 AM Thread Starter
ByrdDog's Avatar
Thanks for the ideas! Think I'll be able to use the k&n intake tube, or am I gonna have to find a factory one?
ByrdDog is offline
post #5 of 8 (permalink) Old 01-03-2011, 07:58 AM
Try the K&N tube first... You may or may not have to mad it because the 6637 filter is much bigger. As long as the K&N tube is a constant 4" diameter you should be able to mod it to fit.
If not, don't worry about looking for another stock tube. Just use a 45* elbow of 4" exhaust tubing. Like the photo below.
Modded L99
post #6 of 8 (permalink) Old 01-03-2011, 11:25 PM
To insure no dirt intrusion, I ran a bead of silicone sealant around the 4" tube after forcing it into the filter opening.
Early 99 F-250 XLT Extended Cab 4x2. XLE4 PCM, BTS Transmission, pre pump fuel filter,CCV Mod, DIY TYMAR, Coolant Filter, 48 Gal Transfer Flow Mid-Ship Fuel Tank
FleetMan is offline
post #7 of 8 (permalink) Old 01-04-2011, 04:30 AM
All done now
Arisley's Avatar
Use hair spray to lube it. It will lube while wet and dry sticky.
OK, Y'all shut up now.
Arisley is offline
post #8 of 8 (permalink) Old 01-05-2011, 10:52 PM Thread Starter
ByrdDog's Avatar
Got it done yesterday; seems to fit tight on the k&n tube just fine. Even with most of the battery box cut away, it's still a pretty tight fit. Did any of you move it a few inches forward?
ByrdDog is offline
