7.3 chip question from newbie - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 12-27-2010, 07:10 PM Thread Starter
my next upgrade will be a Switch-on-the-Fly Six-Position Chip. Here is my question. Once installed can any of these chip tunes be reprogramed by the tuner via email, and reinstalled through the pcm with a laptop or other device?
Once I pull the computer out and replace the chip I would rather not have to do it again. But I may find for example that I like the towing tune but would like the tuner to move the shift points up a little farther. One other thing. Has anyone relocated their pcm to make it easier to access and install a differnt chip later.
thanks
mark
69800 is offline
post #2 of 17 (permalink) Old 12-27-2010, 07:12 PM
All done now
Arisley's Avatar
Re: 7.3 chip question from newbie
With the PCM in the factory spot, I can switch out a chip in less than 20 seconds. Including tape.
To answer your question though, Jody at DP tuner can e-mail tunes, and I think Bill at PHP has that capability.
Arisley is offline
post #3 of 17 (permalink) Old 12-27-2010, 08:28 PM
Village Idiot
southmike's Avatar
with a 6 pos chip you need a burner and a tuner willing to send them.
bill @ php is the only one that i know does that.
jody can do it with an f8 orf6 chip but they are not ts blanks.
southmike is offline
post #4 of 17 (permalink) Old 12-27-2010, 08:55 PM Thread Starter
I can switch out a chip in less than 20 seconds.???
I thought you had to pull the inner fender???
What does this mean.. I planned on getting one of thier cards first and installing it.. then I may want to make a change later .. I can use f6 or f6
69800 is offline
post #5 of 17 (permalink) Old 12-27-2010, 09:04 PM
Millerfarms's Avatar
obs trucks will take longer , the pcm is behind e brake assembly the superduty its a piece of cake
83 f250 460 4x4 4spd ,dana 60 front axle,3;55s ,502ci scj
97 f250 4x4 ccsb,ford cummins,nv5600,271 t case,dana 60, dana 80 , looking for obs cc grey door panels
95 f250 4x4 rclb 4" lift on 35s
Millerfarms is offline
post #6 of 17 (permalink) Old 12-27-2010, 09:06 PM
dustinz85's Avatar
i think you are thinking pf the injector driver module that is in the inter fender the pcm requires you to remove a 10mm bolt that is on a connection though the firewall the pcm is right above your parking park lever in the cab
2001 7.3 Lariat CCSB 4" turbo back duals, 6637 filter mod, DP Custom Tunes, DI RR System, Full Fuel System, Billet 4r100, Precision TC , 160/100 injectors, Leveled
Coming Soon: Springs, Pushrods,238 injectors, 38r
dustinz85 is offline
post #7 of 17 (permalink) Old 12-27-2010, 09:11 PM
All done now
Arisley's Avatar
You don't have to remove the PCM to pull the chip out.
Arisley is offline
post #8 of 17 (permalink) Old 12-27-2010, 09:39 PM
mbg75's Avatar
Like these guys said, once u cut the plastic for the initial install, chip come out in less than a minute
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors
mbg75 is offline
post #9 of 17 (permalink) Old 12-27-2010, 11:12 PM Thread Starter
I thought I read you have to take the top off and clean the contacts before installing a new chip???
69800 is offline
post #10 of 17 (permalink) Old 12-27-2010, 11:14 PM
Re read his quote. It says you dont have to remove the pcm to take a chip out.
To install one on a truck that has never had a chip then yes you have to remove the pcm.
02 f250
countryboyrob is offline
