QSSB Turbo System Installed....my impressions - Page 9 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #81 of 90 (permalink) Old 01-10-2011, 11:26 PM
CGMKCM's Avatar
Re: QSSB Turbo System Installed....my impressions
I don't know of any sponsoring vendors that have them. I will send you a P.M.
[SIGPIC][/SIGPIC]
2001 F-550 4X4 Lariat
BTS Tranny
PHP Phoenix chip
H2E Turbo With WW II
Adrenalin
Banks Intercooler and exhaust
In tank and pre-pump mods
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #82 of 90 (permalink) Old 01-11-2011, 01:20 AM
Village Idiot
southmike's Avatar
What about the purple international, I hear they were the next great CPA.
southmike is offline
post #83 of 90 (permalink) Old 01-11-2011, 01:47 AM Thread Starter
Doakster's Avatar
In the little that I've read about them, they seem to advance timing quite a bit.
I have 3 black CPSs on the way....can't hurt to get a stock of something that will be hard to find eventually.
2003 F-350 4x4 SC 7.3, WOP QSSB Turbo, Isspro Gauges, MBRP 4 inch, AFE Stage II, , DP Tuned Stock, HI, 40t, 60t, 80t, 80e, 120R, 140ex, 6.0 Trans Cooler, 08 Tow Mirrors, 35in Kumho Mts
1993 International 4600 Dump, 7.3 IDI
Doakster is offline
post #84 of 90 (permalink) Old 01-11-2011, 02:39 PM
CGMKCM's Avatar
On FTE they did a bunch of tests recently (30 days) and the tests showed that the one with the purple O-ring was worse then the Lt. Grey (Ford recall).
Ford has a new dark Blue cps but it also is not as good as the Black. The Black is .010 longer and has a bigger magnet.
http://www.ford-trucks.com/forums/10...perdels-3.html
[SIGPIC][/SIGPIC]
BTS Tranny
PHP Phoenix chip
Adrenalin
Numerous minor Mods
Other Diesels
08 GL 320 CDI
02 VW Golf TDI
3054 Kioti Tractor
Kubota ZD 323
CGMKCM is offline
post #85 of 90 (permalink) Old 02-13-2011, 05:47 PM Thread Starter
Doakster's Avatar
It's been awhile since I updated this. After waiting for my new black CPS sensors to arrive and having to send back my EA connector to get replaced, I did a cylinder contribution test.
With the black CPS installed the truck seems to idle smother, and passed the cylinder contribution with no problems.
But, I'm still getting heavy blue smoke on start up, which will go away withing 5-10mins maybe more depending on the outside temperature.
Thoughts? Seems this is an all too common problem, and hopefully in my case it's just an injector O-ring.
After I have that issue resolved I plan on getting new tuning to make the turbo, the truck would probably benefit from tuning to match the turbo.
Doakster is offline
post #86 of 90 (permalink) Old 02-14-2011, 04:15 AM
"Smoke A Lil Smoke"
chappy's Avatar
Do you happen to get fuel from the same place every time? My buddy and I have both noticed if we get fuel from the local shell in this cold weather our trucks smoke blue as well. We go to Citgo on the next tank and it quits. His is a 6.0 and I think his actually smokes worse with the one stations fuel then mine does. Just a thought.
2004 f250 egr delete,studded,fass 95,suncoast convertor,itp RR,Banks intercooler,58v tuned ficm,Powermax turbo,Matts tunes,6in Icon and 35 toyos 20x12 fuels
Early 99 exlb 4wd-SOLD All Shaeffer oil
Will Iott -8/24/84-7/4/10 "We miss you buddy"
chappy is offline
post #87 of 90 (permalink) Old 02-14-2011, 03:28 PM
tree trimmer's Avatar
if i get shell i lose about 1 mpg, if i get bp it seems to run better than any other diesel
2010 f350 srw lariat
tree trimmer is offline
post #88 of 90 (permalink) Old 02-14-2011, 07:47 PM Thread Starter
Doakster's Avatar
It's definitely not related to where i fuel up, I fuel up in a variety of locations, and that doesn't change things for better or worse.
Doakster is offline
post #89 of 90 (permalink) Old 02-15-2011, 03:07 AM
Village Idiot
southmike's Avatar
I got the best w b20.
That is a crazy tractor in your avatar.
Wonder how much traction that would add, w no boggie wheels.
post #90 of 90 (permalink) Old 02-15-2011, 10:55 PM Thread Starter
Doakster's Avatar
You need the boggie wheels to run the tracks, they're for alignment, it's a Ford 8n with half tracks.
Doakster is offline
