Up-pipes..... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 08-14-2007, 04:50 AM Thread Starter
Hated by All
Fast_Ashley's Avatar
Up-pipes.....
Anyone got part numbers for the up-pipe donuts and bolts?
What about the gasket between the collector and the turbo??
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #2 of 14 (permalink) Old 08-14-2007, 05:06 AM
Re: Up-pipes.....
No, I don't have PN's handy. If you really need to reseal all that I'd spend the extra money and get the whole works off a T444E with the bellows in them and not have to worry about it again for a long time.
69W900A is offline
post #3 of 14 (permalink) Old 08-14-2007, 05:11 AM Thread Starter
Hated by All
Re: Up-pipes.....
I got ceramic coated pipes from Black Widow...........just tryin' to put 'em in with new hardware
PARIAH
2001 F-350
post #4 of 14 (permalink) Old 08-14-2007, 02:40 PM
thetonka's Avatar
Re: Up-pipes.....
Powerstroke shop has a kit with uppipes but the kit also lists the part numbers on the website. Can't link to them right now they are blocked by my work proxy.
thetonka is offline
post #5 of 14 (permalink) Old 08-14-2007, 03:04 PM
Martin #6's Avatar
Re: Up-pipes.....
Am I missing something here? I've never seen a gasket between the collector and the turbo.
2008 F-250 Lariat CC 4x4. EPA stock.
Martin #6 is offline
post #6 of 14 (permalink) Old 08-14-2007, 03:21 PM Thread Starter
Hated by All
Re: Up-pipes.....
I could be wrong...........but I was under the impression there was a gasket.
PARIAH
2001 F-350
post #7 of 14 (permalink) Old 08-14-2007, 03:48 PM
Haul_n_horses2's Avatar
Re: Up-pipes.....
I think you should take yours apart again to check. No gasket with mine.
Haul_n_horses2 is offline
post #8 of 14 (permalink) Old 08-14-2007, 03:51 PM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Re: Up-pipes.....
No gasket between the collector and the turbo on the LM 7.3s. The Early 99 may have had one but since I've never taken one apart I could not tell you for sure.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
post #9 of 14 (permalink) Old 08-14-2007, 03:52 PM Thread Starter
Hated by All
Re: Up-pipes.....
Cool.
PARIAH
2001 F-350
post #10 of 14 (permalink) Old 08-14-2007, 06:29 PM
Banned
Re: Up-pipes.....
It's a V-band connection there. They will never use any sort of gasket. The surfaces of the two flanges form the sealing area.
Only flat, bolted flanged turbine inlet connections will use a gasket. And sometimes not even there.
Take it apart and check, it only takes a couple minutes to yank the turbo and take a looksee and toss it all back together.....
Charles is offline
