What could have caused this hole in my piston?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 12-18-2010, 02:15 AM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
I had no compression in #7 so I had the motor torn down after I removed it and there is a hole in the side of #7. As a matter of fact, 1,3,and 5 also have a crack in the top of the piston about a half an inch long. 156k on the truck, reg return installed at 80k when I bought it.
Hole from side of piston - My Photo Gallery
Hole in Piston from Top - My Photo Gallery
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #2 of 31 (permalink) Old 12-18-2010, 02:38 AM
Caption This
444-4D's Avatar
Re: What could have caused this hole in my piston??
Is there nothing wrong with the any of the pistons on the other side?
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #3 of 31 (permalink) Old 12-18-2010, 02:50 AM
< wish it was mine
Stroken7.3's Avatar
2001 F-350, Auto, No Limit Tunes, Autometer Ultra-lite gauges.
Stroken7.3 is offline
post #4 of 31 (permalink) Old 12-18-2010, 02:51 AM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
Exactly, they all look good.
post #5 of 31 (permalink) Old 12-18-2010, 02:51 AM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
Originally Posted by Stroken7.3 View Post
Already, it's not even good yet, .
post #6 of 31 (permalink) Old 12-18-2010, 03:00 AM
< wish it was mine
Stroken7.3's Avatar
I'm sure it will get good.
post #7 of 31 (permalink) Old 12-18-2010, 03:03 AM
Bigfoot is an OBS
cowboy_dan's Avatar
If that had come out of a HPCR engine, I'd say it looks like the injector stuck open. But in this case, I'm guessing it's from poor atomization (dirty injectors nozzles). But, I could be wrong.
Go ARMY!
cowboy_dan is offline
post #8 of 31 (permalink) Old 12-18-2010, 03:09 AM
< wish it was mine
Stroken7.3's Avatar
What do your injector tips look like?
post #9 of 31 (permalink) Old 12-18-2010, 03:18 AM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
I just sent them in with 8 others from another motor I purchased to get a set of 238's for the rebuild but upon inspection, they all looked the same. I don't really know what to look for though. I had purchased a remaned injector to put in before I found out there was no compression and they looked the same also.
post #10 of 31 (permalink) Old 12-18-2010, 04:20 AM
Snake Oil Salesman
mattr66's Avatar
Were all your piston squirters in working order? Did you subject the motor to sustained high EGTs?
Matt Robinson
Gearhead Automotive Performance
Originally Posted by PSDPlayer View Post
If you have nozzles that were Extrude honed over and over and over again. It will look like a porn stars ass.hole where the pintle is supposed to seal.
mattr66 is offline
