"banks" wheel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 12-16-2010, 03:45 AM Thread Starter
way out here
Question "banks" wheel
can someone please explain why i should want (or not) a banks wheel if/when i upgrade to a van turbo? i hear they spose to help with surge but wouldnt a turbo with a 1.15 a/r ratio do the same thing??
i always say you can hear anything if you listen at the right place!
T444E is offline
post #2 of 11 (permalink) Old 12-16-2010, 04:24 AM
Caption This
444-4D's Avatar
Re: "banks" wheel
A Banks wheel will hold more pressure at a fixed flow.
If only those who knew what they were talking about replied, this thread would still be on page one.
2000 F-250 CC 4x4 PSD Auto
444-4D is offline
post #3 of 11 (permalink) Old 12-16-2010, 12:50 PM Thread Starter
way out here
Re: "banks" wheel
OK. But why? I guess im still struggling to understand the science of turbos!!
T444E is offline
post #4 of 11 (permalink) Old 12-16-2010, 01:51 PM
Caption This
444-4D's Avatar
Re: "banks" wheel
The short version of why is, because the blades on the wheel are shaped different. If you want to know why blades shaped like the ones on a Banks wheel will hold more pressure than a wheel that has even blades you are probably going to have to take an Engineering class. And even then you may find the answer is "because the flow machine shows it does".
444-4D is offline
post #5 of 11 (permalink) Old 12-16-2010, 01:52 PM
Village Idiot
southmike's Avatar
Re: "banks" wheel
I was under the impression a van turbo shouldn't surge and not need the wheel.
southmike is offline
post #6 of 11 (permalink) Old 12-16-2010, 06:48 PM
aklim's Avatar
Re: "banks" wheel
Are you having surge issues? My Van turbo didn't have surge.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
aklim is offline
post #7 of 11 (permalink) Old 12-16-2010, 09:07 PM Thread Starter
way out here
Re: "banks" wheel
thats why i asked the question
i`m currently running a stock turbo,and yes it surges like crazy. got a lead on a van turbo rite now but want 2 know if i should put a wheel in it or not.
T444E is offline
post #8 of 11 (permalink) Old 12-16-2010, 09:15 PM
aklim's Avatar
Re: "banks" wheel
Why not wait and see? If it surges you can buy the ported housing which will fix the issue.
aklim is offline
post #9 of 11 (permalink) Old 12-16-2010, 11:20 PM Thread Starter
way out here
Re: "banks" wheel
Good point. iv seen remanufactered Van turbos for sale with the banks wheel installed.... however the one im looking at is a stocker.
If i understand correctly the main benefit of the banks wheel is a slightly higher boost capability?
T444E is offline
post #10 of 11 (permalink) Old 12-17-2010, 01:52 AM
mbg75's Avatar
Re: "banks" wheel
You will see a slight boost psi drop with the banks (ww) and also a drop with the 1.15.
I am running a van turbo with a ww and ATS housing. Overkill with the 2 but I would never go back. Also depends on gearing, tire size and what ur towing.
2002 F-250 ccsb, 7.3, Auto, 4x4, BDP Tunes, Stealth Drop In, 4" MBRP, 6637, Van turbo WW ATS, Frantz Bypass,Drilled & Slotted Rotors
mbg75 is offline
