not your everyday chip problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 53 (permalink) Old 12-10-2010, 10:49 PM Thread Starter
MINK
Comp7.3's Avatar
Well this thing is kickin my a$$, after several months and numerous reburns by multiple people and burners I give in to ask for some help...the chip is simply not responding to the pcm and I am positive the chip is burned correctly. Now one thing I still need to rule out is a knob/cord issue but really how common is that known to be a problem? Second would simply be a messed up pcm but again truck runs great and has no issues yet I cant get the "ts style" chip to work on it, I will admit that I do find it odd that with all stock programming the truck no longer has a speed limiter which is why I cant rule the pcm out as a problem yet; but things just dont seem to add up?
So whats your thoughts? where do I go from here? Im gonna continue to trouble shoot and swap cords and also try the chip on another truck but just wondering what the odds are of a pcm failure....dont tear me up to bad thanks guys
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
post #2 of 53 (permalink) Old 12-10-2010, 11:02 PM
PSN Pretender
907DAVE's Avatar
Re: not your everyday chip problem
How is the J3 port (where chip plugs in)?
Is it possible it was cleaned too much, is there copper showing?
907DAVE is offline
post #3 of 53 (permalink) Old 12-10-2010, 11:13 PM Thread Starter
MINK
Comp7.3's Avatar
its border line....another chip responded on it a couple months back but was wrote for pmt1 so the chip didnt work right....im gonna try the same chip again tonight
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
post #4 of 53 (permalink) Old 12-10-2010, 11:13 PM
HRT Performance
HotRodTractor's Avatar
That damn chip still does not work? Son - its time to try a different computer in there...... When I burned it - did I use your knob and cable, or did I use mine? I thought I had used yours to cycle through the settings while it was on the burner.... but I could be wrong.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #5 of 53 (permalink) Old 12-10-2010, 11:15 PM
PSDfan99's Avatar
Try another PCM maybe?
Early 99 F-350
4" lift on 33's. Daily Driver/ Plow truck.
Swamp's Gen3, 300/200's, Tuning, 76mm Sledgehammer. BTS. Fuel system, ARP's, P-Rods, 910's, and a few other things. Stock Block.
SOLD
New truck:
2009 F-350, 5.4L, 4" lift on 35's
PSDfan99 is offline
post #6 of 53 (permalink) Old 12-10-2010, 11:18 PM Thread Starter
MINK
Comp7.3's Avatar
we used yours, cause mine's mounted all fancy like......so my truck will still run right as it is with a Fd up pcm?
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
post #7 of 53 (permalink) Old 12-10-2010, 11:25 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
It's gotta be the cord... Just stick a cord in there temporarily. I have one you can borrow...
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #8 of 53 (permalink) Old 12-10-2010, 11:29 PM Thread Starter
MINK
Comp7.3's Avatar
I got a friend on his way with a cord that is proven to work but thanks, now if it is a cord problem how much green will it take for you to send me that cord
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
post #9 of 53 (permalink) Old 12-10-2010, 11:55 PM
HRT Performance
If we used my cord it is very possible that your cord is the issue - but I thought I remember hearing the truck "stumble" when switching between the tunes - and I know the truck died when we switched to a position without a tune on it...... I'm thinking PCM still..... but the cord is a easy check.
2015 VW Jetta TDI
2006 VW Jetta TDI
post #10 of 53 (permalink) Old 12-11-2010, 12:05 AM Thread Starter
MINK
Comp7.3's Avatar
okay update: new cord changed nothing so we swapped chips, new chip responded and ran very well although check engine and wait to start light are stuck on along with trans temp and tach not functioning which im gonna blame on chip being wrote for wrong pcm code.....so sense I just had tunes actually work on the truck is the pcm still at fault? we can mark the cord out.......Jason, with this latest reburn im not even getting the "kill" feature out of any position like we did the day or two I was at your farm.....going out to now try MY chip in his 00' truck..
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
