Something just not right. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 12-09-2010, 01:36 PM Thread Starter
bulletproof7.3's Avatar
I have been having a lot of weird things going on with my 00 7.3 with TWM tunes and i was wondering if swamps could reburn their tunes on my chip?
Nothing against Tony at all! I just want to see what else is out there and just asking if this is even possible.
If anyone from swamps can do something PM me. Thanks
2000 f250 , 7.3 built trans, K&N intake, warn lock outs, Tonywildman , 4" down pipe to 5" silverline exhaust, ported compressor housing, 07 hd headlights,trans temp, boost, and egt gauges .
bulletproof7.3 is offline
post #2 of 16 (permalink) Old 12-09-2010, 01:42 PM
The Fireman
big_stroker's Avatar
Re: Something just not right.
If it is a TS style chip then any good tuner here including swamps can burn there tunes on it.
big_stroker is offline
post #3 of 16 (permalink) Old 12-09-2010, 01:43 PM Thread Starter
yeah its a ts.
post #4 of 16 (permalink) Old 12-09-2010, 01:48 PM
Mpoage's Avatar
What kind of problems are you having?
2007 Ford F-250 Lariat Outlaw 4X4
SCT X3 Tuned By Innovative Diesel
Straight Piped
Edge Insight
Mpoage is offline
post #5 of 16 (permalink) Old 12-09-2010, 01:52 PM Thread Starter
The truck a couple weeks ago has a rough idle and wouldnt run right while i was driving. In the 140 hp tune the truck dies after letting off the throttle. So i took the chip out cleaned the contacts and it stopped the rough idle and ran ok. But the 140 hp tune is still out of the question. Now its having weird shift points.
Im not saying that all of this is Tonys fault at all, i just want to see what anyone elses tunes do.
post #6 of 16 (permalink) Old 12-09-2010, 02:02 PM
All done now
Arisley's Avatar
140 tune in a stock truck is pretty much the same as the 100 tune.
Arisley is offline
post #7 of 16 (permalink) Old 12-09-2010, 02:04 PM Thread Starter
Well the daily tune, which ever setting of power that is runs ok but not perfect.
post #8 of 16 (permalink) Old 12-09-2010, 02:15 PM
Village Idiot
southmike's Avatar
new tunes or have they acted up after a while..
southmike is offline
post #9 of 16 (permalink) Old 12-09-2010, 02:16 PM Thread Starter
Newer tunes. like two months old. The 140 has never worked though.
post #10 of 16 (permalink) Old 12-09-2010, 02:48 PM
Village Idiot
southmike's Avatar
have him double check and reburn them ..make sure all mods and pcm codes right
