Rebuild- I only want to do this once-goodies? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 67 (permalink) Old 12-07-2010, 07:03 PM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
My motor is getting rebuilt. I stripped it down before taking it in. I think it broke a ring but will find out. I tow 12k trailer and lots of smaller stuff. I want a truck that is good for towing and more fun than I had from what my sig. shows.
While I am here, this is my list but I am unsure on injectors and new tunes so that is where I think I need help but feel free to advise anywhere.
Trans will come later
Usual stuff like Glow plugs and water pump- 203* Thermo.
Bellowed up-pipes
New HX oil crossover
GTP38R???
Stage I injectors???
New tunes to match up with turbo and injec.?????
Adrenaline and IPR
What else since I am here and advise on ??? please.
Thanks,
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
kilapapipa is offline
post #2 of 67 (permalink) Old 12-07-2010, 08:18 PM
biggreen96's Avatar
Re: Rebuild- I only want to do this once-goodies?
if your going with the adrenaline you wont need the hpx . dieselsite will even tell you not to. just a heads up
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #3 of 67 (permalink) Old 12-07-2010, 08:33 PM
Ticking time bomb
I'd forget the 203 stat and go with a set of stage twos a 38r and have beans tune it, new stealth or adrenaline pump an prolly a reg return with a walbro pump.
I wonder what my sig and avatar will get changed to now!!
groomzybanshe is offline
post #4 of 67 (permalink) Old 12-07-2010, 09:07 PM
I took the HPX off mine recently. I did not notice any improvement with it. I would do the reg return with the injectors.
01 7.3L 152K miles - Alliant AC injectors, ITP regulated return, AIS, bellowed up-pipes, DP tuning, JW trans, DC Power 185A Alternator
darkstar is offline
post #5 of 67 (permalink) Old 12-07-2010, 10:03 PM
Freak'n know it all
gottagofast's Avatar
Just my .02 but I'd say the money spent on the bellowed up pipes could be better spent elsewhere unless yours are badly worn otherwise damaged.... I have 311,000 miles on my original pipes and had one leak just starting.... I replaced that donut and all is well again. I personally am not sold on the durability of bellows.... If they do fail it is a royal PITA to change em out.
Not to start a huge blowup as I know there will be plenty of opinions on this but just offering my thoughts on it.
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #6 of 67 (permalink) Old 12-07-2010, 11:47 PM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
I have a reg return already. Is aWalbro a new fuel pump? Why don't you like the 203*
post #7 of 67 (permalink) Old 12-07-2010, 11:49 PM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
I had a HX on it but to be honest, did not notice a diff. Mine is the first gen though so I thought a new stouter one would be in order. I do have a reg return. I still have everything in my sig to go back on.
post #8 of 67 (permalink) Old 12-07-2010, 11:52 PM Thread Starter
Old Yeller, REBORN
kilapapipa's Avatar
I could just replace the donuts but like I said, I don't want to come back to them and the bellowed seem like the one time fix from what I have read.
post #9 of 67 (permalink) Old 12-08-2010, 12:00 AM
Crazy Canuck's Avatar
i am running the 38r with the 1.0 housing and swamps 175/146 singles, Dp tuning. runs great
2011 F350 CC Dually, Lariat, ultimate package PSD, lock pick, line x, weather guard x box. Pic in avatar.
2000 xcab F250 PSD 4x4 not even close to stock, broken Feb 2011 (collision, write off)
Crazy Canuck is offline
post #10 of 67 (permalink) Old 12-08-2010, 12:01 AM
Ticking time bomb
I'd do the bellowed up pipes and I just don't see the point in spending the money on a 203 thermo seems like a waste to me. The walbro is a bigger than stock pump
