MAP Sensor Signals - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 12-06-2010, 04:16 PM Thread Starter
<--501cc,should b 540 : /
'99 stroker's Avatar
MAP Sensor Signals
What does the MAP send to the PCM as far as signals go? Is there a way to put a resistor in line to make the PCM think you are getting more boost and fuel a little more? Something along the lines of a 10k Mod
Early '99 ccsb 7.3l 4x4 6spd
All Stock Except
Air tank rear bumper
Brush guard w/ fog and driving lights
seat covers
after market floor mats
Fancy Halogen headlight bulbs
Rear license plate light is out
Originally Posted by erikclaw View Post
Those hairy bastards are scary up close!
with all the smoke, power and wheelie popping you might accidently park on a honda
'99 stroker is offline
post #2 of 2 (permalink) Old 12-06-2010, 06:25 PM
Butt-Head
PHPDiesel's Avatar
Re: MAP Sensor Signals
0-5V sensor
0V output from sensor will cause check engine light.
5V output from sensor will cause check engine light.
You want the output to the PCM to be between .4 and 4.8 volts.
If you "fool" the PCM into thinking that the MAP is higher than actual, you will defuel at a lower actual boost reading.
I assume this is for your E99 truck.
If you had a 95-97 truck, the MAP output is frequency based and these tips wouldn't apply.
Cody
PHPDiesel is offline
