Look at my HPOP numbers.. opinions??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 12-05-2010, 10:41 PM Thread Starter
Freak'n know it all
gottagofast's Avatar
So I smoked my engine ant only 311,000 miles and am swapping an engine from a parts truck.
My old one still runs but I burned up #7 piston...
So I took it out to log some data with A/E
At WOT and 2800 rpm I have 3000 psi and a 32% duty cycle I still have stock injectors and besides ww, banks big head, turbine housing and outlet, afe intake and 4" exhaust (I don't think these affect this test in any way) the only power adder for this test was a superchips 1805 set on highest setting
I had two decisions to make from this... the first is to either run my current pump or temporarily put on the 15 deg from the parts truck (not an exciting idea at all) if mine was bad.
At this point I'm fairly sure mine is fine for stock injectors.
My next concern is just how good do these numbers sound? Do I have enough life left in this thing to run some AC's or other street and tow friendly sticks or should I be looking for a pump BEFORE the injectors?
PS my current (AD) injectors are very low mile units and not original to my truck
PPS I know that for the money banks sux but I got a SMOKIN deal on the whole turbo with the goodies already on it
99.5 350 crewcab dually 4x4
stage 1 singles, PHP tunes, banks bighead,
autometer gauges,
, South Bend HD clutch, Gen 2 wicked wheel, AIS intake system.
gottagofast is offline
post #2 of 15 (permalink) Old 12-05-2010, 10:49 PM
<-- it's like that
Re: Look at my HPOP numbers.. opinions???
Ummm.. if you're able to hold 3000 psi at WOT on a tune with a stock HPOP.... that's pretty damn good. Consider yourself one lucky SOB.
If you decide on running AC's later, they'll use LESS oil than the stock injectors. In other words, your pump sounds like it's going to be just fine and dandy for what you need.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #3 of 15 (permalink) Old 12-05-2010, 10:55 PM Thread Starter
Freak'n know it all
NICE that is just what I wanted to hear.... Does it make any difference that the superchips 1805 is probably not making anywhere near the power that a good chip would?
autometer gauges,
post #4 of 15 (permalink) Old 12-05-2010, 11:00 PM
<-- it's like that
Probably. However, you won't know for sure until you get a different chip.
Curtis
2002 F-250 PSD
Pocket is offline
post #5 of 15 (permalink) Old 12-05-2010, 11:05 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
3000psi at 30% duty cycle is SMOKIN...
Joe
CSIPSD is offline
post #6 of 15 (permalink) Old 12-06-2010, 02:36 AM Thread Starter
Freak'n know it all
well cool thanks guys... I'll go ahead and sell the 15deg spare and run this one. I did do the test before the eot had time to get up to temp because I don't want to trash the engine any more than I have too... Sounds like even if it loses a little as eot comes up I'm still doing pretty good.... didn't know AC's used less oil, I thought that was just for hybrids.... I am officially stoked
autometer gauges,
post #7 of 15 (permalink) Old 12-06-2010, 02:53 AM
CSIPSD's Avatar
Any time you can get away from Split shots its a good thing.
Joe
CSIPSD is offline
post #8 of 15 (permalink) Old 12-06-2010, 04:57 AM
Butt-Head
PHPDiesel's Avatar
Most modern tuning that follows the factory's example doesn't allow "full fueling" until the engine is up to operating temperature.
The PCM was likely still not commanding the tuning's maximum injector pulse width at the low EOT.
Cody
PHPDiesel is offline
post #9 of 15 (permalink) Old 12-06-2010, 05:46 AM
Village Idiot
southmike's Avatar
Bill brings up a very good point, but the hpops numbers say bolt that one on first.
Do some tests with the new engine up to temp. And get a good chip. It will have lower egts and such. May make your rngine last a bit longer.
southmike is offline
post #10 of 15 (permalink) Old 12-06-2010, 06:34 AM Thread Starter
Freak'n know it all
man I love this place. I am leaning toward the fu chip but as I understand it I have to go fu2 if I switch to single shots.
I currently have the superchips programmer and a edge juice w attitude.... the juice is not on the truck now and I plan on selling both. Of course then I'll have to get gauges to replace the attitude but then I always wanted to be able to read egt's in both manifolds instead of just the side that didn't blow up
autometer gauges,
