Head parts - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-25-2008, 05:32 AM Thread Starter
Oooo, White Lightning !
Dieselboy's Avatar
Head parts
Looking at parts for my heads
Anyone have the part numbers for the Comp springs ? And the retainers ?
Whats the difference between the 910s and the beehives ?
Who makes exhasut valves ?
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #2 of 12 (permalink) Old 03-25-2008, 05:35 AM
Re: Head parts
Just get the stock IH valves or a good aftermarket source. No need for "high" performance valves from some place like Hypermax, the IH ones are plenty good.
910's are not beehives is the major difference, difference design in the springs. You can also get different spring pressures. I'd go with a set of Crower springs, much higher quality than the off-shore pieces.
69W900A is offline
post #3 of 12 (permalink) Old 03-25-2008, 06:55 AM
Plays with Motors
Machinist's Avatar
Re: Head parts
The IH/Ford and Aftermarket SBI valves are all Inconel and will handle all the egt's you can throw at them assuming good guide work and a proper valve job (for heat transfer).
2011 335i M-Sport
2000 F-250 7.3L ( Sold )
1966 Mustang Fastback
Machinist is offline
post #4 of 12 (permalink) Old 03-25-2008, 12:38 PM
Banning Smut
PTSUPERD's Avatar
Re: Head parts
I run the beehives from Comp Cams.......as does BigR in his race truck.
PTSUPERD is offline
post #5 of 12 (permalink) Old 03-25-2008, 01:19 PM
jibmaster145's Avatar
Re: Head parts
As for the part numbers for 910's, seats, retainers and locks.
910's- 910-16
Seats- CCA-4696-16
Retainers- CCA-795-16
Locks- CCA-617-16
I dont have the part number for the beehives. Maybe someone else can post up with some part numbers.
jibmaster145 is offline
post #6 of 12 (permalink) Old 03-25-2008, 02:12 PM
Haul_n_horses2's Avatar
Re: Head parts
26120-16 IIRC.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #7 of 12 (permalink) Old 03-25-2008, 02:17 PM Thread Starter
Dieselboy's Avatar
Re: Head parts
Sweet, thanks guys..........
Well what is the difference between the 910 and the beehives........Hard to say but is one better suited for what the motor will be intended for ?
What about lifters or rocker arms, what do you guys use ? Ford/ITNL
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
post #8 of 12 (permalink) Old 03-25-2008, 03:00 PM
Re: Head parts
Here are the specs of the two.
Beehives
Part Number: CCA-26120-16
Number of Springs Per Valve: Single
Outside Diameter of Outer Spring (in): 1.445 in.
Coil Bind Height (in): 1.230 in.
Damper Spring Included: No
Spring Rate (lbs/in): 370 lbs./in.
Inside Diameter of Outer Spring (in): 1.000 in.
Valve Spring Style: Beehive
Coated: No
Quantity: Sold as a set of 16.
Notes: O.D at top of spring is 1.095 in. and I.D. at top is 0.650 in.
910's
Part Number: CCA-910-16
Outside Diameter of Outer Spring (in): 1.354 in.
Coil Bind Height (in): 1.280 in.
Damper Spring Included: Yes
Spring Rate (lbs/in): 380 lbs./in.
Inside Diameter of Outer Spring (in): 0.940 in.
Valve Spring Style: Standard
Coated: No
I have the same question. What makes a beehive spring better than a standard spring? Is it better and why? Back to the first question Dieselboy had. "What is the difference" We know that they are not the same style spring but why is one preferred over the other? elaborate..........
post #9 of 12 (permalink) Old 03-25-2008, 03:26 PM
cemeyer's Avatar
Re: Head parts
The beehives are lighter, because the retainer is smaller.This allows more rpms with less spring rate. They also don't have the harmonics of a straight spring either, because of the taper. This should make for a longer lasting spring.
Curt
97 350 CC LB 4x4
Injectors, oil, H2E, studs, 910's, idm, etc...
cemeyer is offline
post #10 of 12 (permalink) Old 03-25-2008, 04:04 PM Thread Starter
Dieselboy's Avatar
Re: Head parts
Thanks for clarifying.................So the beehives would use different retainers and such
Race truck
2002 F-350XL RC/LB
Unlimited 450/400s
TE 17* with Gen3
DI Headers
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
