what the biggest turbo used for towing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 12-05-2010, 12:45 AM Thread Starter
Banned
I am looking at the hx50 for price and the amount of cfm and back pressure. I want to use 238 hybrids. I have a 99.5 truck
sideswipe7 is offline
post #2 of 15 (permalink) Old 12-05-2010, 01:23 AM
The Fireman
big_stroker's Avatar
Re: what the biggest turbo used for towing
I like my 38r for towing with my 238's
I also know Andy (moore20017.3) had a GT4595 I believe and 238's and towed all over the place and loved it.
Just all depends on your setup, tuning and how much you tow
big_stroker is offline
post #3 of 15 (permalink) Old 12-05-2010, 01:28 AM
Caution! May Blow Smoke
Bigcat350's Avatar
38R with a 1.15 housing works for me.
Eddie
Late 01/99 F-350 XLT 7.3 EC DRW 4x4 6-speed 4:10, some common mods done. 6637 filter,Muffler Delete,Stancore GPR, Swamps Hybrid Single Shot Injectors,DP Tuner,CCV, AIH Delete, Foil Delete, Garrett GTP38R BB Turbo with1.15 Housing,Valair, Over 400HP (SOLD)
(FOR SALE)=(SOLD)
Bigcat350 is offline
post #4 of 15 (permalink) Old 12-05-2010, 01:39 AM Thread Starter
Banned
that helps i am just wanting when towing to be able to tap the turbo. I still needed more out of the turbo for like when pulling hills, i dont want to be at the upper end of the turbo when pulling my fifth wheel.
post #5 of 15 (permalink) Old 12-05-2010, 09:48 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
the 38R spools quick and flow's 33% more air at the same boost level as the stock turbo...BP is 1 to 1 up to about 30 lb of boost where a stocker gives up around 20...i think its a damn good turbo if your plans are to stay under 500HP and you tow alot...lots of guy's run the 238's with the 38R so finding a good set of tunes shouldnt be hard...
Ron's power stroke is offline
post #6 of 15 (permalink) Old 12-05-2010, 11:03 AM
The hx 50 should be a great towing turbo, provided it has the right exhaust side on it. It is more or less the same as an H2E.
For Sale: 2000 F350, black cc sb 4x4
Jngreen is offline
post #7 of 15 (permalink) Old 12-05-2010, 12:16 PM Thread Starter
Banned
what exhaust side should i use the only thing that keeping me away from the 38r is, the rebuild kit and the initial price. I saw a rebuild price you could almost buy a new turbo for that price. When I research something I do it right the first time so i dont have to change or worry not liking what i have done. I dont want to have to say change to bigger injectors because they dont give what i am looking for. It sounds like the 238 hybrids is what I want but the second number is still up in the air. 238/?
post #8 of 15 (permalink) Old 12-05-2010, 01:09 PM
The Fireman
238cc with 80% nozzle is all around best injector for towing. 100% wouldnt be to bad ether. But if you going to be towing a lot and heavy go with the 80%
post #9 of 15 (permalink) Old 12-05-2010, 03:26 PM Thread Starter
Banned
you should know i have been reading your post on you for a while. Now here is a question wouldnt doing head work and a cam make it so you can go higher in nozzle size.
post #10 of 15 (permalink) Old 12-05-2010, 04:40 PM
Addicted
addison's Avatar
you can run stock 30, 80, 100, 200 nozzles and tow its all in tuning, 300, 400, you could tow with just need to be tuned right, head work is only going to make your heads flow more air so you can burn more fuel, cam is going to change where your power is in the rpm range, if your tuner is good you can tow with any injector.....
addison is offline
