Single Shots w/Split Shot Tuning - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 12-03-2010, 09:19 PM Thread Starter
Busted Knuckles
PSDEng's Avatar
I'm pretty sure I know the answer to this question but I want to verify. I'm putting my old single shot injectors in my friend's 2001 truck. How is it going to run with the split shot tuning he has until he gets his chip back. The ONLY reason I'm putting them in is due to time constraints (I need my core charge back). I know the idle will be really bad, but other than that can he run it?
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #2 of 11 (permalink) Old 12-03-2010, 09:35 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
Re: Single Shots w/Split Shot Tuning
yup, it'll run and drive around ok, i wouldnt go on long trips or any highway
CCLB with some stuff done .....
BigRed97 is offline
post #3 of 11 (permalink) Old 12-03-2010, 09:39 PM
fueled by Colecovision
golfer's Avatar
Garage
it should run fine....and actually drive quite smoothly.
the only "issue" would be that the pedal may be "touchy"...at throttle tip-in...and a rolling idle (upppp....downnnn....upppppp....downnnn...)< still would be smooth, not missing or anything.
other than that...it's not a big deal....drive it all you want.
golfer is offline
post #4 of 11 (permalink) Old 12-03-2010, 09:47 PM Thread Starter
Busted Knuckles
PSDEng's Avatar
Sounds good guys thanks. While I have yall's attention I have another question. I've changed many a set of injectors on OBS trucks, have it down to a science almost, is there anything different to look out for on SD trucks?
PSDEng is offline
post #5 of 11 (permalink) Old 12-03-2010, 10:05 PM
<-- it's like that
It'll take a little longer thanks to the intercooler pipes. But other than that, no difference.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #6 of 11 (permalink) Old 12-03-2010, 10:05 PM
The Oracle
BigRed97's Avatar
intercooler pipes
BigRed97 is offline
post #7 of 11 (permalink) Old 12-03-2010, 10:12 PM Thread Starter
Busted Knuckles
PSDEng's Avatar
No different on the clearance issues with the heater box or anything?
PSDEng is offline
post #8 of 11 (permalink) Old 12-03-2010, 10:13 PM
The Fireman
big_stroker's Avatar
I ran my truck on the stock tuning for a few days b4. Same as Golfer said just idle rough and touchy throttle
big_stroker is offline
post #9 of 11 (permalink) Old 12-04-2010, 12:46 AM
<-- it's like that
I've never had an issue, and I've yanked all of my injectors out twice.
Curtis
2002 F-250 PSD
Pocket is offline
post #10 of 11 (permalink) Old 12-04-2010, 02:14 PM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
fuk sd's ..... lol. but yup thats exactly how it will run.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
