Tuners and Builders advice on injectors, what do you recomend. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 121 (permalink) Old 12-03-2010, 04:10 PM Thread Starter
I know nothing...
joedaddy's Avatar
Buying injectors for an OBS, want 500hp capable DD with the manners of a stocker.
Is this possible? I wouldn't have thought so b4 but now?
The inj I'm looking at are 250/200. Is 200% resonably tunable through the mail?
Will a 66 be big enough to clean them up or with I need to get big air?
Just want to spend the money once. I also think a lot of guys like me who are still learning would like to know but are afraid to ask.
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #2 of 121 (permalink) Old 12-03-2010, 04:21 PM
strokeorcroak's Avatar
Re: Tuners and Builders advice on injectors, what do you recomend.
Im not a tuner but id like to hear what bean, matt, jonathan, tony, and jody have to say about this...
Or anyone else doing self tuning.
I believe you wont have any trouble tuning those to operate like stock(ish), but that setup is going to be to much for a 66. Its not going to clean up great, though it will definitely spool great. But my fear is it wont last very long. The 66 has been tested with 250/100 and 238/100 but that nozzle make quite a difference.
Tuners? lets here it
1996 with 35s
615hp/1258tq on 9/19
strokeorcroak is offline
post #3 of 121 (permalink) Old 12-03-2010, 04:38 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
Definately too much fuel for a D66. I think you can get good enough street manners as well.
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #4 of 121 (permalink) Old 12-03-2010, 04:41 PM Thread Starter
I know nothing...
joedaddy's Avatar
That's my worry to, I'm going with adrenaline oil as well and I know its good to 238/80 but don't know how much farther. The 66 should be good to that level as well. Also I'm guessing ill need studs but anything else internal?
Its been 2 years since I came and asked these same ?'s you'd think in 2 years id know the answers but this ain't gas, it it ain't easy. I'm a perpetual newb I'm afraid
joedaddy is offline
post #5 of 121 (permalink) Old 12-03-2010, 04:42 PM
z_racing14's Avatar
This is absulutely doable! Check my truck - 523hp , 1148ft-lbs torque on 250 -100's and a 38r. Pulls trailers way better than a stocker wt cooler egt's and drives like a #####cat if you want it to. I have one tune that does it all...just use your right foot as the limiter Matt for the tuning and Nate from Unlimited Diesel for the injectors --and all injectors are not created equal, just ask me how I know These guys are both geat and have unreal customer service. Feel free to ask about anything you want about drivability. I have a bunch of videos posted up in the stage I cam thread.
2000 CCSB: AFE StgII, 38R, Ported Heads, Arp's, Gearhead StageI Cam, 912's, Unlimited Diesel 250-100's, DI Headers, Spearco, RR, Fuel Lab, Gearhead Tunes.
523hp 1148ft-lbs
z_racing14 is offline
post #6 of 121 (permalink) Old 12-03-2010, 04:48 PM Thread Starter
I know nothing...
joedaddy's Avatar
^^^apreciated but I have a source for the parts and tuning. I'm just trying to get boned-up on the "why" of what I want.
joedaddy is offline
post #7 of 121 (permalink) Old 12-03-2010, 05:09 PM
d66 and 38r are differnet turbos....
I wouldnt suggest this build on a d66
1996 with 35s
post #8 of 121 (permalink) Old 12-03-2010, 05:12 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
250/200 and a Modded H2e is what I am running now. Its a great set up, but can be smokey above 5k. You have to drive around it a bit.
No EGT issues unless I am pulling heavy and get caught in the wrong gear...
Joe
CSIPSD is offline
post #9 of 121 (permalink) Old 12-03-2010, 05:28 PM Thread Starter
I know nothing...
joedaddy's Avatar
5k????? Doubt ill get up there. You do mean alt not RPM correct?
joedaddy is offline
post #10 of 121 (permalink) Old 12-03-2010, 05:46 PM
a modded h2e would be a good turbo..
a gqssb has potential to be even better..
I would try to get rid of the 66, unless your going to turn those injectors down and adjust shift points to keep the drive pressures under control
1996 with 35s
