FASS wiring question.HELP ASAP - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 03-24-2008, 02:46 AM Thread Starter
Hey guys,Im in the shop trying to button up the FASS system and have a question on the wiring system. FASS didnt send any literature on the wiring so I am a bit in the dark on what to do. I know there was a post earlier about this topic but it sounded like that may have been an earlier model FASS kit.
From the FASS pump there is a harness that goes into a relay and from the realy you have a two pin connector and on the other end it goes through a fuse to two bare wires. now I am assuming that this is similar to a Hella light kit where they want you to get direct power from the battery switched by a source that may not handle the amp draw which is the reason for the relay. So where the two pin connector is could be hooked up to the factory fuel pump wires since this is only going to close the relay to pull duirectly off the battery. It doesnt take much amp draw to close a relay so I dont think a guy would never have an issue going through the factory wiring to do so.
Am I on the right track????
Damn FASS for not sending a wiring diagram. I am in a huge crunch to get this truck done and on the road and makin money!!!
Thanks in advance.
Justin
Black Star is offline
post #2 of 18 (permalink) Old 03-24-2008, 02:48 AM
Mr. Bob's Avatar
Re: FASS wiring question.HELP ASAP
I am running my FASS right to the factory wiring for the factory pump.... I was under the impression that the factory wiring was PLENTY good enough to power a FASS..... Mine has been for like 6 months anyhow....
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #3 of 18 (permalink) Old 03-24-2008, 02:51 AM Thread Starter
So which wires did you eliminate?
I would assume the relay and also the fuse could go by what your saying??
It would be fused through the factory harness right?? I thought the same as you. The wires on the frame are good heavy wires. Im not sure why FASS is using all the other stuff.
post #4 of 18 (permalink) Old 03-24-2008, 03:02 AM Thread Starter
Andrew thanks for the link on PM to the instruction manual. According to that I may be missing a pigtail that plugs into the two pin connection and goes into the cab to a IGN on source. Then the bare wires would go directly to the battery. Well #### I guess I amy have to improvise
So it is what I thought. You would end up running the two pin connection to a source that is hot when ignition is turned on and in turn it would close the relay and pull directly off the battery.
Oh by the way I was missing a page in my instruction manual.GO figure.
post #5 of 18 (permalink) Old 03-24-2008, 03:07 AM
Mr. Bob's Avatar
Yep... Mine is using all the stock wiring.... So Ford provided me with a fuse and a relay and all that....
I hooked the 2 wires that went to the stock pump right up to my fass pump and away I went.....
Mr. Bob is offline
post #6 of 18 (permalink) Old 03-24-2008, 03:29 AM
00PSD1's Avatar
your welcome Justin. So yours came with a relay?
Andrew
2000 F250 EX LB 4x4 XLT
00PSD1 is offline
post #7 of 18 (permalink) Old 03-24-2008, 04:17 AM
DarkShadowDiesel's Avatar
is this a 150/180 (high pressure) or low pressure model?
if it's high pressure the stock pump gets eliminated - no need to worry about the wiring. just put the hot wire on the batt or in fuse box and then ground.
2002 F250
DarkShadowDiesel is offline
post #8 of 18 (permalink) Old 03-25-2008, 02:29 PM
Village Idiot
southmike's Avatar
the big boy might need larger gauge wiring then the OEM pump had..not sure but would be my guess, that is why some people run the new wire from the battery and a relay...
southmike is offline
post #9 of 18 (permalink) Old 03-25-2008, 02:44 PM
you can just use the wiring that comes with it...
2002 F250
post #10 of 18 (permalink) Old 03-25-2008, 02:47 PM
Village Idiot
southmike's Avatar
isn't there a thread kinda on this where you said it comes with relay's etc...
or is that only di's version.
