Mini-Me's - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 08-13-2007, 04:50 AM Thread Starter
Hated by All
Fast_Ashley's Avatar
Mini-Me's
What exactly is a Mini-Me?? What makes them different from stage 1,2 and 3's?? Can I run them in my PMR truck without shoving a rod through the block???
PARIAH
2001 F-350
Resurection has begun.....
Fast_Ashley is offline
post #2 of 23 (permalink) Old 08-13-2007, 05:01 AM
HP Junky
Re: Mini-Me's
Mini Me is a stage III. It's a hybrid injector. and i wouldn't dare run them on pmr's.
with pmr's i think you need to stay with stock nozzles.
RockinJW is offline
post #3 of 23 (permalink) Old 08-13-2007, 05:05 AM Thread Starter
Hated by All
Re: Mini-Me's
Do you think stock nozzled stage 2's would be alright??
PARIAH
2001 F-350
post #4 of 23 (permalink) Old 08-13-2007, 05:14 AM
HP Junky
Re: Mini-Me's
Stage One's are anywhere from 160cc-180cc with stock nozzles
Stage Twos are the same 160cc-180cc but with aftermarket extrude honed or edm'd nozzles
A stage one and stage two are generally the same injector, they just put different nozzles on them
RockinJW is offline
post #5 of 23 (permalink) Old 08-13-2007, 05:33 AM
PwrStrokinDually's Avatar
Send a message via AIM to PwrStrokinDually
Re: Mini-Me's
It's perfectly safe to run Mini-Me's on a PMR equipped engine, HOWEVER, I would have them detuned!!! At least, until you upgrade your rods.
Danny Om
01 SC PSD Dually (build date 08-00 w/ PMRs), 8" Edge, dual F&R Doetsch aluminum shocks w/ resevoirs, 37" SSR on all 6 tires, 2" (hub & wheel centric) wheel adapters by Fearless Fred Goeske, Fabtech racing track bars.
Fully built motor w/ B-codes, GT42R, and Terminator w/ Remote IPR HPOS.
PwrStrokinDually is offline
post #6 of 23 (permalink) Old 08-13-2007, 06:09 AM
Re: Mini-Me's
this may be stuped but what is pmr
sledpuller is offline
post #7 of 23 (permalink) Old 08-13-2007, 06:13 AM
Re: Mini-Me's
Kainers is running 530 hybrids with stock nozzles. That is the absolute BIGGEST I would go.
Mini Me nozzle size scares me, although Dzacc is still holding it down.
Good tuning is a must!!!
I like to think of mine as stage 1.5's . I think anything in the 180-200cc range can be tuned to run safe with stock nozzles.
Mini me's are 238 cc with big nozzles, a walk on thin ice IMO.
Kainer's 530's are 250cc????? but stock nozzles. Still quite a bit of fuel.
gregrob is offline
post #8 of 23 (permalink) Old 08-13-2007, 06:15 AM
Re: Mini-Me's
PMR = Powdered Medal Rods
I will add that to the acronym list
gregrob is offline
post #9 of 23 (permalink) Old 08-13-2007, 12:19 PM
Banned
Re: Mini-Me's
Just toss in a set of BD's with stock nozzles. I did 428rwhp on that setup with two pumps. Well, they were technically BI's, but they were nozzle limited.
If you just ran on the single OEM pump you would probably nose down before you had a chance to get up on top of them. Although you would still be capable of moving more fuel at any pressure than an A-code like a stage II.
B codes are ~6:1 whereas A codes are ~7:1. B codes use less oil than A codes for any given fuel flow.
Did I mention that full B-codes are cheaper than hybrids?
Charles is offline
post #10 of 23 (permalink) Old 08-13-2007, 01:26 PM
A Ghost these days.
mad_matt's Avatar
Send a message via Yahoo to mad_matt Send a message via Skype™ to mad_matt
Re: Mini-Me's
I ran bd codes on my PMRs and I was and am running .0075 EH tips. I broke. That was due more to the fact that I like to push the upper limits more so than the Injectors I was running. 530s are big fuel no matter how you look @ it. I'd say stick with agressive stage 2s if you want to stay safe.
Got Boost?
Slightly modded 01 F350 CC SB 4X4
Powered by Oil driven by Madness.
Post Injector upgrade Spin: 577/944
Dynojet
HP: 597 BWD Superflow
13.152 @ 104.7 mph
Mods: Everything plus the Twins.
In the mail: Everyone's stuff but my own
Planned upgrades: sho mods!
mad_matt is offline
