Exhaust Brake probs? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-24-2008, 01:29 AM Thread Starter
Heading down the hill today pulled the switch, went to shut it off nothing hit the throttle nothing, floored it nothing but black smoke. pulled over couldn't get it to free up. So finally i pulled the relay under the dash and it was fine. What would cause this bad relay bad switch any ideas. Its the Bd exhaust brake i think its the older model with the big actuator on it.
Thanks Rusty
Stroker85 is offline
post #2 of 8 (permalink) Old 03-24-2008, 02:07 AM
Re: Exhaust Brake probs?
Check to see if the switch is ok. If it is then the relay is probably bad. They do wear out. Everytime the relay pulls up the contacts you get an arc that will eventually cause the relay to fail. Put another 3 dollar relay in it and drive it until it fails again.
69W900A is offline
post #3 of 8 (permalink) Old 03-24-2008, 02:14 AM
Banned
Send a message via Yahoo to blk99
I dont know what causes it but mine did that EXACT thing a couple weeks ago.... I have the same brake...
just replaced the relay and it is good as new.... relays just wear out
blk99 is offline
post #4 of 8 (permalink) Old 03-24-2008, 02:26 AM Thread Starter
thanks for the help guys i will try that.would it be a bad idea to replace the switch on the shifter as well?
post #5 of 8 (permalink) Old 03-24-2008, 02:28 AM
Banned
No do the relay first.... it is just a standard relay....
I have a feeling the switch is fine
blk99 is offline
post #6 of 8 (permalink) Old 03-24-2008, 03:11 AM
Custom Trailer Sales
TrailerHauler's Avatar
relay's are a couple dollars, do that first!
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #7 of 8 (permalink) Old 03-24-2008, 11:48 PM Thread Starter
sprayed some high temp lube in the vaccum lines and it works fine.
Thanks
rusty
post #8 of 8 (permalink) Old 03-25-2008, 08:05 PM
getting blocked eh?
