Autometer LP oil and water temp gauge. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 11-29-2010, 10:43 PM Thread Starter
< wish it was mine
Stroken7.3's Avatar
Where is the best place to tap into for low pressure engine oil gauge and the best place to tap into for coolant temp gauge? These are for the ultra-lite gauges that match my boost and pyro.
2001 F-350, Auto, No Limit Tunes, Autometer Ultra-lite gauges.
Stroken7.3 is offline
post #2 of 2 (permalink) Old 11-29-2010, 11:25 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Autometer LP oil and water temp gauge.
Oil Pressure...
two choices...
Or
Second one will give you more of a lube oil pressure, first one tells you whats in the HPO res...
Water temp...
if you have a coolant filter this has a secondary function of telling you when the filter is clogged...
Joe
CSIPSD is offline
