Towing Power - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 46 (permalink) Old 03-23-2008, 08:39 PM Thread Starter
Smile Towing Power
I am going to step up to Big Oil. I have been waiting for the New Stealth, but I also like the BTS setup. I know my pump is getting weak, I set off the ses light on a long grade. Does anyone have any expereince with the BTS?
01' F250 PSD CC 4x4, GTP38R, Hi-Flow outlet, DI Bellowed up-pipes, BTS Hpop, DI Regulated return, ITP Annilator, AM 3pod, AFE PG7 Stage II, Silverline 4in T-Back, 6.0 Trans cooler, Dp F5, BTS Trans, True-Trac 3.73, Powerslot Cryo, Rotella ELC, Nitto Terra 285/75/16E on Alcoa wheels
Torque37 is offline
post #2 of 46 (permalink) Old 03-23-2008, 09:13 PM
Needs more hours per day
jtharvey's Avatar
Re: Towing Power
I've had my BTS Dual HPOP for nearly 3 years, roughly 30K miles, and have been 100% happy with it. I don't drag race the truck a lot or sled pull it any, but I think I do hammer on it pretty hard for a DD, and tow probably once a month or so. The only problem I have run into was about a month ago, a fitting on one of the braided high pressure lines developed a leak at the crimp. I called BTS once I found the leak and they overnighted me a new set of lines, all on their dime, no questions asked. Other than that one issue, which was easily and quickly resolved, I couldn't ask for anything else out of it...and before anyone says it, I have no desire for extreme ICP. The BTS HPOP setup does it's job, does it well, and doesn't complain.
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #3 of 46 (permalink) Old 03-24-2008, 02:38 AM Thread Starter
Re: Towing Power
Jtharvey what kind of numbers are you making? I am wanting to get 325-350hp. I was told by Bean that I could get there with a Big oil, Stock inj and 1.15 ex housing. I wonder how much lag I would have with 1.15 ex.
Torque37 is offline
post #4 of 46 (permalink) Old 03-24-2008, 02:53 AM
Mr. Bob's Avatar
Re: Towing Power
I was running 295 RWHP with chip on 80E, intake and exhaust....
I bet with Big Oil and proper tuning 325 would be achievable... 350 might be a bit of a stretch...
1.15 ex housing is the same as the van turbo... Some say its a bit more laggy, but with the right tunes manageable...
There is also a 1.00 non wastegated that might be a good option for you if you plan to keep with stock injectors....
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #5 of 46 (permalink) Old 03-24-2008, 03:07 AM Thread Starter
Re: Towing Power
I plan on running my stock injectors until they quit. Then I might might go with Stage 1 Singles. Also I already looked and I do have PMR's. If I was to put a non wastgated housing on, would I have to worry about exceeding the safe boost limit of the stocker?
Torque37 is offline
post #6 of 46 (permalink) Old 03-24-2008, 03:09 AM
Custom Trailer Sales
TrailerHauler's Avatar
Re: Towing Power
I have been leaning more toward the turbo for my towing upgrades just because its less than big oil.
I think big oil would also be a good choice, I've heard good things about BTS and terminator
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #7 of 46 (permalink) Old 03-24-2008, 03:12 AM
Mr. Bob's Avatar
Re: Towing Power
the 1.00 or the 1.15, which ever you decide, will help bring down the boost a little.. That housing combined with the ATS housing you already have should give you a really good turbo setup that a lot of people like ( van turbo with ATS housing )
Mr. Bob is offline
post #8 of 46 (permalink) Old 03-24-2008, 03:24 AM
Re: Towing Power
That's a great system!
TerminatorEngineering is offline
post #9 of 46 (permalink) Old 03-24-2008, 03:27 AM
Oooo, White Lightning !
Dieselboy's Avatar
Re: Towing Power
Umm does anyone have expirience with this "terminator" Guy
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #10 of 46 (permalink) Old 03-24-2008, 03:28 AM
jtharvey's Avatar
Re: Towing Power
I'm guessing you're wondering about the power I made with stock injectors...because I'd estimate I'm ~450 RWHP right now with the B Codes.
However, with the stock injectors and everything else I have in my sig except for the headstuds, I was around 360 RWHP. The truck weighs 8000 lb and ran a 15.0 @ 87 mph, backed up by an identical run later in the day. The calculators here show 357 HP using trap speed. That was with nearly every other supporting mod - intake, exhaust, van turbo w/ATS housing, Spearco 7.3 IC, fuel system, BTS trans, BTS dual HPOP, and DP-Tuner chip.
Jeremy
jtharvey is offline
