Installing regulated return - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 03-22-2008, 10:47 PM Thread Starter
I am installing a regulated return system and I cannot get the AC compressor mount to come off. Is it just those three bolts that hold it in or is there more? Thanks for the help.
2003 7.3 XLT FX4, AFE Stage 2, Regulated Return, Bowl Delete, 3/8" line from tank to heads, Pre/Post Filters, Tank mods, DP F5: 60T, 80E, 120R, 6.0 IC, 6.0 Trans Cooler, Suncoast Shift Kit, Wicked Wheel, ITP Boost Annihilator, Di Procol Optix, Straight Pipe, CCV, 285/75/16 BFG AT's
breyrw is offline
post #2 of 25 (permalink) Old 03-22-2008, 10:49 PM
Re: Installing regulated return
Pull the HPOP res, much easier.
gregrob is offline
post #3 of 25 (permalink) Old 03-22-2008, 10:51 PM Thread Starter
anything special I need to be aware of to remove the hpop resevoir?
breyrw is offline
post #4 of 25 (permalink) Old 03-22-2008, 10:53 PM
It will spill a lot of oil if you don't suck it out first.
gregrob is offline
post #5 of 25 (permalink) Old 03-22-2008, 10:55 PM
moose99ps's Avatar
there is 4 bolts i believe.
early 99, xcab, 8"lift,37" toyo open country m/ts, afe stage II,BDP tuning, 5" black chrome aussie cuts, blacked out bumper and grill, 8 isspro performax guages, stealth dual pumps, a few fuel leaks......
mods to come:
NO SACRIFICE..... NO VICTORY!
moose99ps is offline
post #6 of 25 (permalink) Old 03-22-2008, 11:10 PM Thread Starter
where is the fourth one at? The tensioner pulleys get right in the way.
breyrw is offline
post #7 of 25 (permalink) Old 03-22-2008, 11:11 PM
moose99ps's Avatar
i dont remeber exactly...
wait i never took it off.. its a pain but it can be done. and then use a socket to pull the restrictor out
mods to come:
post #8 of 25 (permalink) Old 03-22-2008, 11:17 PM
Proud PSN Sponsor
Deputydog's Avatar
I just did my reg return. I recall 4 bolts holding the AC compressor down, all 4 were on top. There are two electrical connectors as well. I just took the 4 bolts off and the connectors and moved it aside and was able to gain access to the front port.
820 HP on 05/19/12
Toll Free 866-379-8685
Deputydog is offline
post #9 of 25 (permalink) Old 03-22-2008, 11:48 PM
Mr. Bob's Avatar
Thats all I did.... pull the 4 bolts from the top of the AC compressor, unplug the electrical connector and swing the compressor out of the way..... I didn't pull the bracket off, and I didn't take the HPOP res off either....
1995 Ford F350 XLT CC LB, 4X4, 12V Cummins, ZF5, D60, Sterling 10.5, 6637 air filter, 7.3L Intercooler, Autometer Cobalt Gauges. ZF6 swap soon to come
Mr. Bob is offline
post #10 of 25 (permalink) Old 03-22-2008, 11:55 PM
moose99ps's Avatar
X3
mods to come:
