DP F5 issues... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 03-22-2008, 04:11 AM Thread Starter
SUPERDF350's Avatar
DP F5 issues...
Just installed a new F5 from Jody. On a long drive up north in california at night I had some after market fog lights on. As I was pulling a grade a car came oncoming to me so I switched off the lights and the F5 screen went blank and the truck surged. So I thought it was my foot so I tried it again and it did it again. So I tried it again with no throttle and it was fine.
So the lights have a 30 amp fuse, and the screen only goes blank when you are driving with throttle. Anyone have ideas. I dont want to have any problems with the F5.
2003 F-350 CCLB 4x4 6 spd man 5.5 Fabtech, 4"turbo stright piped,DP Tuner, hi-idle,40,60,80,100,120, ATS housing wicked wheel, tymar intake,firestone airbags.
SUPERDF350 is offline
post #2 of 24 (permalink) Old 03-22-2008, 04:15 AM
<----Colin Banks
mattymx's Avatar
Re: DP F5 issues...
Odd... BUt overall how did you like it on the first long drive?
mattymx is offline
post #3 of 24 (permalink) Old 03-22-2008, 04:17 AM
Re: DP F5 issues...
I'd start with the simple things like check the grounds on the aftermarket lights, check to make sure the PCM is clean enough, etc.
69W900A is offline
post #4 of 24 (permalink) Old 03-22-2008, 04:23 AM Thread Starter
SUPERDF350's Avatar
Re: DP F5 issues...
Level 1 Stock:
2250RMPs
67MPH
14LBS boost
800+* EGTs
Level 7 120HP
2250RPMs
67MPH
8LBS boost
640 EGTs
Throttle was about only 1/4 or less compared to 1/2. I need to put a scan gauge to see what % of pedal. So far the truck runs awesome except for the one issue.
post #5 of 24 (permalink) Old 03-22-2008, 04:25 AM
<----Colin Banks
mattymx's Avatar
Re: DP F5 issues...
That is an impressive look at stock vs. the 120 file. Very cool.
mattymx is offline
post #6 of 24 (permalink) Old 03-22-2008, 04:26 AM Thread Starter
SUPERDF350's Avatar
Re: DP F5 issues...
The ground is hooked to the Batt. And the PCM was just out and it is pretty keep. I dont know how much more I can do with that. I will check the ground tomorrow.
post #7 of 24 (permalink) Old 03-22-2008, 04:28 AM Thread Starter
SUPERDF350's Avatar
Re: DP F5 issues...
More tests to come. Between the rest of the files. I need to figure this one issue out.
post #8 of 24 (permalink) Old 03-22-2008, 04:33 AM
Re: DP F5 issues...
i would try calling Jody...see what he says.
good luck!
PMRCM#1
slowleak is offline
post #9 of 24 (permalink) Old 03-22-2008, 04:35 AM Thread Starter
SUPERDF350's Avatar
Re: DP F5 issues...
I think he is in AZ. for some live tuning so I will have to wait tell next week. I almost dont want to use it and burn the chip up if something is wrong.
post #10 of 24 (permalink) Old 03-22-2008, 04:37 AM
<----Colin Banks
mattymx's Avatar
Re: DP F5 issues...
Just keep those lights off until you talk to him. maybe Diane will see this tomorrow and give you some info.
mattymx is offline
