Injector press ratios, nozzle size, fuel atomization, and a "Reverse Hybrid".... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-20-2008, 07:21 AM Thread Starter
<---Beer version of PMR's
Seven3Leeter's Avatar
Was doing some reading lately about the difference between A codes, B codes and Hybrids; have some questions about fuel atomization and pressure ranges and how they effect mileage, power, ect.
From what I can gather from Bigr's sticky on the main 7.3 page:
1) A codes have a 6mm plunger and a 16mm intensifier piston and = 7:1 icp ratio
2) B codes have a 7.1mm plunger and 17.5mm piston and = 6:1 icp ratio
3) Hybrids have a 7.1 plunger and 16mm pistion and = 5:1 icp ratio
So, there must be then an inherant drawback in lowering icp ratio such as less optimal atomization, but while loosing psi you are gaining fuel flow at the same given High press oil flow. Is this on track?
Also, I was wondering what role nozzle size plays in the final fuel psi in the cylinder during combustion? Ok, If a person for instance was running Big Oil at say 3600psi of icp with an A code injector you would see a 25,200psi at injection correct? And 21,600psi with a B code, and 18000psi with a hybrid at the same given amount of HPO capacity. So, obviously the hybrid would be flowing much more fuel than the A code but at a lower press. Does nozzle size change the final ratio and the amount of oil need to supply? If so, what are the real world differences in say towing for instance with a theoretical difference of 7,200psi of injector press between the A and the Hybrid?
Ok, another thought. If there are benifits to much higher injector psi (I think the Dmax and Cummins common rails run like 25000psi+ dont they?) could a person build a "reverse hybrid" (for heavy towing) with a 6mm plunger and a 17.5mm piston and make 8:1 icp ratio? If so, I'm sure you'd need big oil but, geeze; 3600psi of icp @ 8:1 = 28800psi. Whats yer thoughts? Thanks, 'Leeter
Tuning by Sniper
Transmishing by John Wood
Breathing by AFE
Exhausting by Pinncle
Monitoring by me and Isspro
Compressing by Wicked Wheel
Wasting by Turbomaster
Stopping by Powerslot
Lifting by Donahoe
Rolling by Toyo
Protecting by Ranch Hand, God, and Ruger
Addiction by
[SIGPIC][/SIGPIC]
by Garrett, Alliant, ITP, DP-Tuner
Seven3Leeter is offline
post #2 of 6 (permalink) Old 03-20-2008, 04:37 PM
What else?
smokyred's Avatar
Re: Injector press ratios, nozzle size, fuel atomization, and a "Reverse Hybrid"....
Dzljim has run reverse hybrids, he said they were having trouble with tuning last I heard.
And nozzle size will affect injection pressure. I think if you actually developed 25k psi, you may have injector internal sealing problems.
Dave
smokyred is offline
post #3 of 6 (permalink) Old 03-20-2008, 08:24 PM
doh
gregrob is offline
post #4 of 6 (permalink) Old 03-21-2008, 12:02 AM
Stupid Kid
(correct)
(Not really)
(bigger nozzle will yeild less psi at the tip and not as good attomization, but has a higher fuel flow bigger nozzles do tend to be more oil thirsty than smaller nozzles cause the fuel flows faster do to less resitance but the Intensifier piston moves faster due to less resistance and that is why it uses more oil)
(In theory but I believe that that is not even close those numbers would be true if there were no hole in the nozzles)
(Same as above)
(IMHO a hybrid probably has a higher injection pressure at the nozzle than either a b code or an a code)
(oil yes but the ratio still stays the same)
They dont work very well. Oil cont enter the injector fast enough to make that pressure.
Thanks, 'Leeter
How do I do the bold letters instead of using these ()
thedieselkid is offline
post #5 of 6 (permalink) Old 03-21-2008, 12:13 AM
<----Colin Banks
mattymx's Avatar
Click and drag the text you want in bold. Then go to the top of the reply box and hit the letter "B" on the left. Then you should see the tags [B ] your bold text here[B ]. but without the space between the B and last ].
mattymx is offline
post #6 of 6 (permalink) Old 03-21-2008, 12:23 AM
Remember that all those numbers are theoretical and may not pan out in real world driving. A lot depends on the condition of the injectors, HPO system, engine, etc.
BD is one of the best performing injectors for big HP all around. It has decent injection pressure, flows quite a bit of fuel and is relatively easy on the HPO for the amount of fuel injected. But to run BD's you have to have good supporting mods.
Hybrids are the best bang for the buck in the big fuel department on injectors alone. The nice thing about these is that you can run stock HPOP and still get a decent running truck. You do end up a bit short on the IP which is the reason that hybrids tend to be a bit more smokey but a lot of that can be tailored with tuning.
Reverse hybrids are a great idea, but so far I don't think there have been any really successful sets built yet. Injection pressure is important, but it's not everything. What injector you go with depends largely on what the use of the truck will be and how much power you want.
69W900A is offline
