3.73 to 4.10 Gear Swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 61 (permalink) Old 03-20-2008, 02:48 AM Thread Starter
Deepsky3539's Avatar
Just found out my F250 (with a towing package), has a 3.73 diff . Has anyone here swapped a 3.73 for a 4.10 rear end? My 12# trailer is really getting the best of my truck. If so, was it expensive to have done? Can you buy and do your own easily? etc ....?
2001 F250 Extended Cab 4x4
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Magnaflow 4" Exhaust
Turbomaster Wastegate Controller
Dieselsite engine and intercooler boots
Pricol Optix gauges
DP Tuner= No Start, Stock, 80 Econo, 40 HA Tow, 140 Race
Lots-o-surge
Deepsky3539 is offline
post #2 of 61 (permalink) Old 03-20-2008, 02:50 AM
Banned
Re: 3.73 to 4.10 Gear Swap
its not bad at allif you have a 2 wheel drive. but if you have a 4x4 you have to a lot more work to pull the axles out. with the rear you can remove the axles without even removing the wheels.
whiteduallyil is offline
post #3 of 61 (permalink) Old 03-20-2008, 02:51 AM
Gear sets are about 400 each for the front and rears. About 30 bucks each for install kits and around 150 for bearing kits if you decide to do bearings. They are easy enough to change, but you do have to set stuff like pinion pre-load, gear pattern, etc. If you don't you'll trash the gears in no time.
All SRW SD's have 3.73 or higher gears. Only way to get 4.10's was in a dually.
69W900A is offline
post #4 of 61 (permalink) Old 03-20-2008, 03:41 AM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
not exactly true My work 00 F350 is a SWR and its got 4.10s its a lariate and everything so its not just a cab chassis which could be different
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #5 of 61 (permalink) Old 03-20-2008, 04:09 AM
Depends on exactly how you coded it when it's ordered. There are ways to get 4.10's in a SRW truck, but you can't just order a F350 pickup and get 'em. To this day you can't just walk in and order a SRW F350 with 4.10's unless it's a gas pot.
69W900A is offline
post #6 of 61 (permalink) Old 03-20-2008, 04:55 AM
Engineering College Boy
Got Diesel's Avatar
Send a message via AIM to Got Diesel Send a message via MSN to Got Diesel
12k# trailer shouldn't really give your truck a work out. Especially not with some tow tunes or something along those lines.
Kyle
Early 99 F-250SD 7.3 PSD 4x4. Auto, tymar type intake, straight pipe, Six inch stacks, Tony Wildman Four position chip, Street race, 80 Tow, 80 Econo, Extreme. Let the smoke roll. Upgraded torque converter. Autometer Ultralights on the Pillar. Running Cooper Discover STT's.
SLAPS MEMBER
Got Diesel is offline
post #7 of 61 (permalink) Old 03-20-2008, 05:09 AM
Going Crazy
yea i dunno how it was done but i know it was ordered with um some how back in 00
-Richard-
post #8 of 61 (permalink) Old 03-20-2008, 05:24 AM Thread Starter
Between the new boots and the DP Tuner on the way, I should be good I suppose. Tightening my boots has already helped a great deal but they are definitely still leaking a bit.
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Pricol Optix gauges
Lots-o-surge
post #9 of 61 (permalink) Old 03-20-2008, 05:41 AM
Banned
Send a message via Yahoo to blk99
the truck in sig has 3.73 and it does just fine.... even with a gross of 30K....
blk99 is offline
post #10 of 61 (permalink) Old 03-20-2008, 06:47 PM
Powerstrokeless
What size lift and tires are you running. I have a stock 350 dually with 3.73's and it pulls great even up around 25-30K gross. 4.10's are not fun on the road unloaded. If you are not towing all the time or lifted out the roof I would stick with the 3.73's
2005 Chevy 3500 crew cab dually allison auto.
2007 dodge 3500 QC dually 5.9 cummins, 6-spd.
phale is offline
