Need advice on new 17* or Big Oil with my injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 03-19-2008, 05:02 AM Thread Starter
I need advice on either getting a new or good used 17* hpop and a new IPR or going with a big oil setup. The problem I'm having right now with my 15* pump and original IPR (200,000 miles on both) is I'm only getting 1500 to 1800psi at WOT which I'm reading off my new HPOP oil gauge in the cab. I'm also only seeing 1500 to 2000 psi on the gauge when I roll into the throttle just coming off a stop light, is that nomal? The injectors I'm running are made by DPS and are stage 3 hybrids 238cc. They were in the truck when I bought it so thats all I really know about them. I know everyone is going to say go with big oil but it is alot of money so I what I need to know is upgrading to a 17* going to help my problem or is big oil the only way? Also just reading through some of the threads I've read that just changing out your IPR with a new mit solve alot of my problem or is that just a mith? Any help from some of you guy that have experience with this would help alot.
P.S. I'm also only getting 13mpg and alot of black smoke with barely any throttle
2008 F350 Harley Davidson CCSB
Mod:
S&B intake, DPF delete pipe, H&S XRT pro 300hd tune, Edge CTS gauges, Newton 2 1/2" leveling kit, Newton 5 1/2" Traction bar blocks, 305/60R20 tires on stock HD rims
Combs19 is offline
post #2 of 24 (permalink) Old 03-19-2008, 05:25 AM
Oooo, White Lightning !
Dieselboy's Avatar
Re: Need advice on new 17* or Big Oil with my injectors
Well the smoke might be because your running a stock 99 1/2 turbo..........Unless you just didnt put it in your sig......
I would just get the 17* if your worried about money
However You would benefit alot from a set of Termys.......
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #3 of 24 (permalink) Old 03-19-2008, 05:34 AM
A healthy 17 will help, but it's not enough and that's a fact.
If I can help, let me know.
TerminatorEngineering is offline
post #4 of 24 (permalink) Old 03-19-2008, 05:43 AM Thread Starter
Yeh, sorry couldn't fit any more stuff in my sig. I running a GDS ball buster turbo or the same thing as a early TN turbo before the BB.
Will changing out the IPR help as well or is that a mith?
Mod:
Combs19 is offline
post #5 of 24 (permalink) Old 03-19-2008, 05:51 AM Thread Starter
I mit be hitting you up when I save up the money.
Do you know what pressures I should be seeing as I roll into the throttle as I leave a stop light? I know its a hard question, but if your half way into the throttle should it be higher then 2000psi or is that normal? What I think I'm trying to say is with big oil does the pressure slowly go up to 3200psi by the time your at WOT or does it move right up to that with a little throttle?
Mod:
Combs19 is offline
post #6 of 24 (permalink) Old 03-19-2008, 05:52 AM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
pretty sure its all on throttle input, very light on the throttle wont get a full 3500psi or what ever... pegging it will
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #7 of 24 (permalink) Old 03-19-2008, 06:23 AM
A lot of it depends on your tunes. I would say your 2000 number is close. Max ICP really depends on what your tuner is demanding, and when. And of course, if the pump is capable of producing that requested demand.
post #8 of 24 (permalink) Old 03-19-2008, 09:19 AM
Crazy Redneck
UNCOOL's Avatar
Or your injectors are really hosed up.
Try a new IPR and let us know.
Not all 15 degree pumps are created equal. Mine was a Wednesday built pump.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #9 of 24 (permalink) Old 03-19-2008, 10:17 AM
Haul_n_horses2's Avatar
Exactly. So just monitoring the HPOP is insufficient. If his IPR is at 20% duty cycle when it is putting out the 1800 psi, he may just need improved programming. However I would bet he needs more oil.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #10 of 24 (permalink) Old 03-19-2008, 01:00 PM Thread Starter
Yeh, I think mine was built on Friday around 6:05pm
I think I mit just try a new IPR first since I'll need one anyway if I go with big Oil.
Mod:
Combs19 is offline
