6.0 Intercooler and transmission lines - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 03-18-2008, 01:30 PM Thread Starter
When installing a 6.0 intercooler onto a 2003 7.3L is it possible to just bend the lines out of the way, or does the tranny cooler have to be replaced with a 6.0 cooler? I have heard two different stories, that the lines can be bent on the earlier trucks, but not on the 02-03 trucks. Any help from people with experience is greatly appreciated.
2003 7.3 XLT FX4, AFE Stage 2, Regulated Return, Bowl Delete, 3/8" line from tank to heads, Pre/Post Filters, Tank mods, DP F5: 60T, 80E, 120R, 6.0 IC, 6.0 Trans Cooler, Suncoast Shift Kit, Wicked Wheel, ITP Boost Annihilator, Di Procol Optix, Straight Pipe, CCV, 285/75/16 BFG AT's
breyrw is offline
post #2 of 10 (permalink) Old 03-18-2008, 01:42 PM
Haul_n_horses2's Avatar
Re: 6.0 Intercooler and transmission lines
I have a Spearco 6.0 IC and had no problems with the AC plumbing.
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Haul_n_horses2 is offline
post #3 of 10 (permalink) Old 03-18-2008, 01:58 PM
Oooo, White Lightning !
Dieselboy's Avatar
Why not just buy the tranny cooler as well............
Race truck
2002 F-350XL RC/LB
NADP Race Trans/PCS'd
Lowered w/ traction bars
Unlimited 450/400s
S475 on Irates mount
TE 17* with Gen3
DI Headers
Dieselboy fuel system
[email protected]
599.3 on BDs dyno
Tow pig
2000 F-250XLT EC/SB
Tuned
Exhaust
Intake
Dieselboy is offline
post #4 of 10 (permalink) Old 03-18-2008, 02:08 PM Thread Starter
I found a good deal on the IC and snatched it up pretty quick, I guess I am just trying to do the swap for the least amount of money. It would be nice to have a new trans cooler, but the cheapest new 6.0 tranny cooler is twice what I have in the IC and for that amount of money I would rather go on to some fuel system upgrades.
breyrw is offline
post #5 of 10 (permalink) Old 03-18-2008, 02:33 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
I just built a bracket and lowered both the PS cooler and the tranny cooler...
File Type: jpg drop bracket for Tranny and PS coolers.JPG (47.0 KB, 36 views)
Joe
CSIPSD is offline
post #6 of 10 (permalink) Old 03-18-2008, 03:50 PM
<-- it's like that
I did manage to bend mine and make it fit, but I only did it as a temporary solution because I was getting a BTS the following month. Not something I would recommend since it's not a pretty job. I'm surprised the lines held together long enough to not spew trans fluid all over the place. Rocky at Rockin-S Performance got a good laugh when he saw my handy work.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #7 of 10 (permalink) Old 03-18-2008, 07:52 PM Thread Starter
I will get under there and look around to see how bad it is whenever it stops raining here, but if the overall consensus is that it won't fit, then there may be an IC for sale.
breyrw is offline
post #8 of 10 (permalink) Old 03-23-2008, 03:40 AM
Some Kinda Diesel Oracle
thehammer69's Avatar
You need to replace your tranny cooler with a Pre-Feb 2001 cooler or use a 6.0 tranny cooler. I would not trust bending as a permanent solution.
Hammer
2002 Corvette Z06...my Auto-X, track car, and play toy
2001 Ford F250 Lariat 7.3PSD...daily driver
2000 BMW 328i...another daily driver for the GF
1997 Yamaha YZF1000R
1995 Volvo WIA-64TTES w/ Cummins N14-500hp/1750 ft/lbs
1994 Chevy Camaro Z28...will be selling soon
thehammer69 is offline
post #9 of 10 (permalink) Old 03-23-2008, 07:00 AM
I just cut the 45* fitting off my V10 cooler that I had laying around and welded it back on so it wouldn't interfere. Since I already had a few V10 coolers laying around the mod and install was basically free (or 130 bucks if you count the cost of the cooler). Clears my aftermarket 6.0 with zero issue.
69W900A is offline
post #10 of 10 (permalink) Old 03-25-2008, 02:35 PM
Village Idiot
southmike's Avatar
do the ealier trucks have this problem?
is it because the tranny lines go into the radiator and the cooler?
hopefully, I don't think my early 99 has them so maybe it is an easier drop in.
southmike is offline
