Wastegate Install (Remove Turbo or not)? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-18-2008, 02:19 AM Thread Starter
Deepsky3539's Avatar
Cool Wastegate Install (Remove Turbo or not)?
I have a Turbomaster wastegate controller on my list to order but wanted to know if I was going to have to remove the turbo to install it. If so, I am assuming I might as well order new gaskets. ITPDIESEL has them real cheap so no concerns on price.
If I do have to remove it, I will probably wait until then to hook up my EBPV exhaust brake wiring and to replace the engine boots.
If you hadn't guessed, I am doing a pile-o-upgrades here in the next month. Listed below for perusal.
- Intercooler and engine boot replacement (them's is some leaky suckah's).
- Turbomaster wastegate controller.
- 4" exhaust (Turbo Back).
- 203 degree thermostat.
- DiPricol gauges (Pyro, Trans Temp, Boost).
- DP Tuner.
Most of these choices are thanks to the advice from this group, so thanks in advance.
2001 F250 Extended Cab 4x4
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Magnaflow 4" Exhaust
Turbomaster Wastegate Controller
Dieselsite engine and intercooler boots
Pricol Optix gauges
DP Tuner= No Start, Stock, 80 Econo, 40 HA Tow, 140 Race
Lots-o-surge
Deepsky3539 is offline
post #2 of 9 (permalink) Old 03-18-2008, 02:22 AM
Banned
Send a message via Yahoo to blk99
Re: Wastegate Install (Remove Turbo or not)?
no you dont have to take the turbo off.... the little C clip is a little difficult to get off but not too bad...
blk99 is offline
post #3 of 9 (permalink) Old 03-18-2008, 02:53 AM
DILLIGAFF
Send a message via AIM to Redfish
Make sure you have a butt load of those C clips.... there is probably a half a dozen sitting in my valley somewhere.
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #4 of 9 (permalink) Old 03-18-2008, 02:56 AM Thread Starter
I will head over to the local dealership and get a gallon bucket full.
"Air Lift" Air Bags
DIY #6637 Intake
DIY Exhaust Brake
Zoodad
Pricol Optix gauges
Lots-o-surge
post #5 of 9 (permalink) Old 03-18-2008, 03:01 AM
DILLIGAFF
You can get them at Napa, I believe they are 1/4" C clips...... dont just buy one box, get two.... trust me
14.09 @ 94 1.85 60'
Redfish is offline
post #6 of 9 (permalink) Old 03-18-2008, 03:04 AM
Banned
I have never lost any of them.... not even the one on the wastegate!
blk99 is offline
post #7 of 9 (permalink) Old 03-18-2008, 03:04 AM
yup, napa "curcular linkage clips" They are not the normal c-clip, much, much easier to get back on there. part #7352640.
2002 F250 7.3 PSD
Dyno Proven Tunes
scheidt27 is offline
post #8 of 9 (permalink) Old 03-18-2008, 03:40 AM
Deputydog's Avatar
Whenever I pull my engine I'll be curious to see what all in my engine valley.. Probably a few sockets, wrenches, fittings, my glass eye..
Deputydog is offline
post #9 of 9 (permalink) Old 03-18-2008, 06:17 AM
Layson's Avatar
My turbo is coming off when I install mine... It is such a pain to get back there...
It can be done without removing the turbo though..
Layson is offline
