What is the best clutch - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 03-18-2008, 12:38 AM Thread Starter
ELKHUNTER's Avatar
I just installed the F5 on the 550 Friday and the clutch wont hold. witch is the strongest on the market?
Thanks for any input.
Josh
2000 F350 205,000
STAGE II SPLITS 100%
STEALTH SRP1
TYRANT TUNES
38R TURBO
BTS VALVE BODY
WALBRO 392
SCANGAUGE
ISSPRO
MORE STUFF
ELKHUNTER is offline
post #2 of 13 (permalink) Old 03-18-2008, 12:47 AM
Banned
Send a message via Yahoo to blk99
Re: What is the best clutch
I have been told that if you tow the the SouthBend CON OFE is awesome... if not towing the CON FE.... because the FE is strickly a "on and off" type of clutch....
but I THINK Charles has the FE and he tows....so
blk99 is offline
post #3 of 13 (permalink) Old 03-18-2008, 12:51 AM
The OFE drives nicer and is good to 500hp IIRC. The FE will hold more power but it's more agressive on engagement. It's really what you are willing to put up with as far as driving manners.
If that isn't enough you can step up to a double disk.
69W900A is offline
post #4 of 13 (permalink) Old 03-18-2008, 12:52 AM
What else?
smokyred's Avatar
How far are you gonna take the truck? I would get a South Bend personally, but the specific model will change if you're gonna build the motor a little or alot.
Dave
smokyred is offline
post #5 of 13 (permalink) Old 03-18-2008, 12:53 AM
2nd class citizen
1snotrocket's Avatar
yep im getting the south bend con ofe.put my big oil in and dp tuner and had 1 clutch flare when i pulled my trailer.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #6 of 13 (permalink) Old 03-18-2008, 01:59 AM
HRT Performance
HotRodTractor's Avatar
I just got my South Bend Iron Giant But that is WAY more than a street truck needs.
I would go ahead and get the double disk. I loved the way mine drove on the street before I went all nuts on the motor. Model depends on what you are going to be doing with the truck.
Jason
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #7 of 13 (permalink) Old 03-18-2008, 02:16 AM
What else?
smokyred's Avatar
Jason, by Iron Giant do they mean you have to be an Iron Giant to bolt the clutch in, or you have to be an Iron Giant to disengage the clutch?
I personally don't mind the feel of the dual disc in the trucks I've driven, I wouldn't say it's something to let your grandma borrow to go to the grocery store though, lol.
Dave
smokyred is offline
post #8 of 13 (permalink) Old 03-18-2008, 02:30 AM
HRT Performance
Dave
BOTH! The box weighs in at 118lbs..... and I am sure it will give a new meaning to a firm peddle.
2015 VW Jetta TDI
2006 VW Jetta TDI
post #9 of 13 (permalink) Old 03-18-2008, 02:37 AM
Banned
will probably brake a leg once it catches/engages!!!!!
blk99 is offline
post #10 of 13 (permalink) Old 03-18-2008, 03:05 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
I have the Con-FE and I am very happy with it. I tow very often..
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
