FASS system wiring? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 36 (permalink) Old 03-17-2008, 02:15 PM Thread Starter
I make smut cry
FASS system wiring?
I just got my DI performance/FASS system and no clue where to wire in the supplied harness for the fuel pump. Where's the best place to tie into?
Cowboy Steve
Powerstroked162 is offline
post #2 of 36 (permalink) Old 03-17-2008, 09:27 PM
DarkShadowDiesel's Avatar
Re: FASS system wiring?
fuse block
2002 F250
DarkShadowDiesel is offline
post #3 of 36 (permalink) Old 03-17-2008, 11:40 PM
Going Crazy
badluck_early99's Avatar
Send a message via MSN to badluck_early99
I just did mine right to the battery.. works great
1999 F250 PS 6spd, 37x12.50x17 ProComp Xmud, 06 Grill & Lights. DP tuner, Terminator Hpops, Garrett 42, Casserly B codes, FASS Fuel system by DI, H11's, ITP Reg Return W/Bowl Delete, Sknab 6oh Intercooler, DIY Intake, 4'' Exhaust, Itp OBA, Autometer boost and pyro, , ccv
-Richard-
badluck_early99 is offline
post #4 of 36 (permalink) Old 03-18-2008, 01:19 AM
2nd class citizen
1snotrocket's Avatar
wire it to the fuse box on the fused side so it will blow if theirs a problem or if a pump burns up.
2003 CRW CAB LB 4X4 6SPD,AFE STAGE 2,38r,DP TUNER,4'' MBRP,FASS 15,Farmers Disel Performance 160/100 injectors,ITPREG.RETURN,TERMINATOR
2001 crw cab short bed auto 4x4 5"exhaust afe stg 2,f6,jw trans,terminator,cass. stg2's,itp reg return,fuel lab pump.
1snotrocket is offline
post #5 of 36 (permalink) Old 03-18-2008, 01:56 PM Thread Starter
I make smut cry
What fuse did you wire it to?
Cowboy Steve
post #6 of 36 (permalink) Old 03-18-2008, 03:54 PM
you should be able to pick an empty one - i cant check til sat or sun but i am sure DI could tell you
2002 F250
post #7 of 36 (permalink) Old 03-18-2008, 04:58 PM
Village Idiot
southmike's Avatar
I have seen different meathods, the neatest install I saw was a relay from the oem pump. they probaby pulled supply feed from fused circut off the battery. but using the relay powered it up as soon as the oem pump would have.
southmike is offline
post #8 of 36 (permalink) Old 03-18-2008, 05:01 PM
Going Crazy
Thats exactly how the FASS system is built, a realay activated by the stock pump wires turns on the new hot wire that is already fused, so it could be wired in to the fuse block but there is already a fuse on it so its not 100% nessicary it could be wired right to a power source no prob
-Richard-
post #9 of 36 (permalink) Old 03-18-2008, 06:34 PM
why would you do that when they give you a relay?
2002 F250
post #10 of 36 (permalink) Old 03-18-2008, 07:49 PM
Village Idiot
southmike's Avatar
well I guess it wasn't such a novel idea after all.
he probably just used the parts out of the box and the directions i guess
...here i thought he had a great idea...
