water tank mounting - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 03-16-2008, 10:02 PM Thread Starter
00PSD1's Avatar
water tank mounting
Has anyone mounted their water tank on the frame rail? If so please post up some pics.
thanks,
Andrew
00PSD1 is offline
post #2 of 20 (permalink) Old 03-16-2008, 10:07 PM
Laces Out
bigrpowr's Avatar
Re: water tank mounting
what kind of tank? how big? is it for taking showers? cant wait to read about this install!!!
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #3 of 20 (permalink) Old 03-16-2008, 10:08 PM Thread Starter
00PSD1's Avatar
6 gal tank from coolingmist for water injection
00PSD1 is offline
post #4 of 20 (permalink) Old 03-16-2008, 10:47 PM
Go Away I'm Baitin
fishinfool98's Avatar
Send a message via AIM to fishinfool98
andrew
mount it where it is gonna be easy to refill
06 CCLB SRW grey first mod was PSN sticker
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
fishinfool98 is offline
post #5 of 20 (permalink) Old 03-16-2008, 10:48 PM
Go Away I'm Baitin
in a tool box works best since it keeps it out of the weather
Sailors may come
Sailors may go
post #6 of 20 (permalink) Old 03-16-2008, 10:50 PM Thread Starter
00PSD1's Avatar
I would like to mount it in the tool box but i need the space for my tools. If I bought one of those cargo racks and moved the spare tire of the tool box I would have plenty of room to put it there
but if its possible to mount it on the frame and stay safe then that would be easier for me
00PSD1 is offline
post #7 of 20 (permalink) Old 03-16-2008, 10:53 PM
Go Away I'm Baitin
i dont see it being a prob execpt for filling
how would you fill the tank being mounted on the fram the fill necks gonna be a pita to get to
Sailors may come
Sailors may go
post #8 of 20 (permalink) Old 03-16-2008, 10:57 PM Thread Starter
00PSD1's Avatar
I was thinking about that. maybe I could put together something like a little bit of piping coming out to top and then going to side with a check valve that would connect to the hose
00PSD1 is offline
post #9 of 20 (permalink) Old 03-16-2008, 11:41 PM
ΜΟΛΩΝ ΛΑΒΕ
Stroked95's Avatar
There should be enough room behind the fuel fill door for a garden hose style attachment to fill you frame mounted tank. You could make a tank out of some bigger diameter PVC pipe with caps on each end. Just some thoughts, IDK if any of it would work.
2005 F-250
Tuning by-Gearhead Automotive & Innovative
Performance Truck Products
Stroked95 is offline
post #10 of 20 (permalink) Old 03-17-2008, 12:17 AM
Layson's Avatar
Problem is filling the tank... it has a twist on cap just like a gas tank. Mine is going in the tool box.
One thing to remember is the pump should be installed below the tank...
Layson is offline
